586,069 active members*
3,721 visitors online*
    Nov 2017
    Mitre fold realy thick board
    I have need to cut miter fold v groove in 38 mm (1"1/2) thick mdf with melamine outer layer. Reality is that I have CNC with 1.5 kw spindle (ER16 collete) and no room in shop for router table. Existing bits for that large profile are all 1/2 shank size and best I can find for 1/4 shank size is 3/4" or so in depth. So I was thinking to make multiple passes with smaller v bit to achieve same effect. As a newbie I made strategy with 6 passes (see attachment) but I'm not sure is that manageable in real situation and where are pit falls. Or are there some other methods?
    Re: Mitre fold realy thick board
    That method should work fine.
    But I've always found miterfolding with a router bit to be problematic, as it's difficult to get a consistent thickness, and a clean cut at the tip. Melamine and laminates always seem to chip a little. I have much better results when miter folding veneered panels.
  1. RFQ .125" thick lens board in 6061 Aluminum
    By nSomnius in forum North America RFQ's
    Last Post: 04-06-2017, 02:44 AM
  2. Fold Back!
    By logger in forum Cincinnati CNC
    Last Post: 05-01-2013, 11:46 AM
  3. Mitre CNC cutting
    By I.J. CNC in forum European Club House
    Last Post: 05-28-2010, 05:41 PM
  4. realy need help
    By heilcnc in forum Stepper Motors / Drives
    Last Post: 03-16-2006, 10:31 AM
