586,060 active members*
4,449 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Omni CNC > OMNI 1325 purchase from 3 months and still waiting???
Page 2 of 4 1234
Results 21 to 40 of 68
  1. #21
    Mar 2013
    39
    Re: OMNI 1325 purchase from 3 months and still waiting???
    Ok Zoprano
    What is your experience with the machine?
    Are you satisfied ?
    thank you
  2. #22
    Jul 2017
    40
    I still do not have the machine.
    I finalized the purchase a few days.
    Enviado do meu iPhone usando o Tapatalk
  3. #23
    Mar 2013
    39
    AH ..ok zoprano
    I hope you will not have delay problem.
  4. #24
    Mar 2013
    39
    Please ALLEN
    don't forget the Email also.
    Every UPDATE here must be also given on Email.
    thanks
  5. #25
    Cnc have been finished, working video will be sent to you soon.
    Check 1325 cnc router XYZ working area
    https://youtu.be/AK3eUAotd58
    Attached Thumbnails Attached Thumbnails IMG_20171209_114700.jpg   IMG_20171209_114906.jpg   IMG_20171209_115124.jpg
  6. #26
    Mar 2013
    39
    very good...thank you
    waiting for other video to see it in working.
    best regards
  7. #27
    Pls check samples picture,working video is loading up to Youtube.
    Attached Thumbnails Attached Thumbnails IMG_20171212_151505.jpg   IMG_20171212_153559.jpg   IMG_20171212_163145.jpg   IMG_20171212_150759.jpg
  8. #28
    Step mode test
    Choose 1 point position, XY into 0, spindle down to drill 1 hole, then chose step mode, input X 100mm. then spindle move 100mm, spindle down to dill second hole, then use tape to test 2 hole distance, It prove that fact distance is still 100mm.
    Attached Thumbnails Attached Thumbnails IMG_20171212_163949.jpg   IMG_20171212_164047.jpg
  9. #29
    1325 cnc router engraving Laker'logo on MDF for Sofnacef
    https://youtu.be/G_xURjpS81E
  10. #30
    Mar 2013
    39
    thank you for your update.
    Please give me a clear images of :
    1- electronics parts in the cabinet.
    2- omron switches and Over travel limited stop.
    3- lubrication system.
    best regards
  11. #31
    Pls check control cabinet picture, 380v3 phase
    Attached Thumbnails Attached Thumbnails QQ??20171213141636.jpg   IMG_20171212_150825.jpg
  12. #32
    Lubrication system on Cnc
    Manual lubrication pump connect X Y Z axis each Hiwin blocks (1325 cnc total 12 blocks , Y 4 sets,X 4 sets,Z 4 sets blocks) and Z axis ball screw, Do 3 times lubrication before using cnc work each day.
    Attached Thumbnails Attached Thumbnails QQ??20171213141643.jpg   QQ??20171213141742.jpg   QQ??20171213150431.jpg   QQ??20171213150418.jpg
  13. #33
    Limited stop
    1 Setup soft limited stop in Weihong NK105 control system, then X 1300mm,Y2500mm,Z300mm.
    2 3 pcs Omron limited stop on X Y Z. go home function and limited stop function.
    3 hard limited stop, 2 pcs on X axis, 4 pcs on Y axis.
  14. #34
    Mar 2013
    39
    Hello allen
    Please I want more video test of the machine.
    cut small round shapes
    cut complex shapes forms
    best regards
  15. #35
    Mar 2013
    39
    hello Allen
    Please I am waiting for more video test of my machine.
    square shapes
    best regards
  16. #36
    Jul 2017
    Same here, been waiting for same as much almost for one 1530 carrousel atc.. i've been in china i know how much they lie.
    They usually send you pictures of other people machined, and i can prove this after a couple of times dealing with them
    Yes there was an inspection but they use it as an excuse for everything.. never trust anyone with such stuff..
    I have switched to a new reliable supplier.. making higher quality machines in less than a month, in china you
    Must meet your supplier in person and always research..
    And even in your first order don't go big.
    Quote Originally Posted by sofnacef View Post
    hello Allen
    square shapes
    best regards
  17. #37
    Mar 2013
    39
    nazihdev thank you for your advise.
    This is my first experience with chines machines.
    Until now my only problemwas after purchase with the delay.
    Mr Allen is giving me the photos like you see here and I trust him now.
    If I found any problem that you talk about I will mention it here.
    Any way I will give all my experience with this machine in the future.
    I still waiting for video tests of the machine and some specific pictures.
    I hope it will finish good.
    Best regards
  18. #38
    Mar 2013
    39
    hello Allen
    Please I still waiting for :
    video about :
    1- cut small round shapes*
    2- square shapes
    3- cut complex shapes forms
    Also :
    4- clear photo of the shneider swichs.
    5- clear photos of all (servo motors* + spindle) labels* *( serial number model ......)
    best regards
  19. #39
    Hi
    4- clear photo of the shneider swichs. It is in the control cabinet ,you can find it in old picture or attached.
    5- clear photos of all (servo motors* + spindle) labels* *( serial number model ......) There are serial number about spindle in old picture, you can find it in the page1 or attached picture , now motor is inside motor cover, Kindly check old picture .
    .Any update about your shipping plan? Your agency did not reply me about balance ,shipping time for a longer time than us.Hope you have a same standard for us.
    Cutting MDF video link as bellows:
    1325 cnc router cutting MDF for Nacef
    https://youtu.be/RJEJWq8ho58
  20. #40
    India customer's feedback about Allen and Omni
    https://youtu.be/LXtR0UYph2E
    https://youtu.be/tTAPjrZx83U
Page 2 of 4 1234
  1. Replies: 10
    Last Post: 04-09-2019, 08:48 AM
  2. Replies: 2
    Last Post: 11-16-2017, 11:07 PM
  3. OMNI 1325 Ordered
    By swarfmeister in forum Chinese Machines
    Last Post: 10-28-2016, 08:14 AM
  4. omni 1325
    By bill flesher in forum Chinese Machines
    Last Post: 10-28-2016, 08:10 AM
  5. OMNI-CNC 1325 on its way!
    By Jzarski in forum Chinese Machines
    Last Post: 10-28-2016, 08:09 AM
