586,116 active members*
3,338 visitors online*
    Nov 2017
    1996 partner 6
    I'm just hooking up my mill on a 3phase converter and it has transformers on side of machine from the previous owner does anyone have an idea why I'm no electrician but obviously, the way they have them hooked up is to step down the volts so it's not overpowered and my American rotary phase converter produces what its suppose to. Do I even need the transformers? thanks for any input
    Nov 2013
    128
    If it's a DC machine, why not just run it on 220 single phase? L1 & l3 to your hot legs and jumper l1 & l2. Any rotary phase converter is going to give you a wild leg, the generated leg. Turn it on and check to ground, I'll bet it's somewhere in the neighborhood of 280 volts and will vary with load. If you do decide to use the rotary, be sure the generated leg is connected to l2, the center leg on the disconnect.
  1. Parting out 1996 Kiaturn 21
    By mrogowski in forum Hyundai Kia
    Last Post: 05-14-2016, 11:07 PM
  2. Old 1996 Citizen L20
    By DRRoman in forum CNC Swiss Screw Machines
    Last Post: 04-30-2015, 06:55 PM
  3. Traub CSK 300 VMC Fanuc 0m 1996
    By CNCkris in forum Machinery Manuals / Brochures
    Last Post: 12-13-2012, 11:29 PM
  4. Pro's and con's buying 1996 HAAS VMC
    By djnbig in forum Haas Mills
    Last Post: 06-14-2008, 03:03 PM
  5. Bridgeport Vmc 1000 1996
    By skydivebase in forum Bridgeport / Hardinge Mills
    Last Post: 05-08-2007, 11:18 AM
