586,060 active members*
4,328 visitors online*
    Sep 2017
    7
    Squaring the x axis gantry
    So I’m trying to square up my x axis, and having issues. It’s measuring .01” higher on the right side, than the left, where the green lines are. All the holes and machine screws seems to be self centered, with no room for adjustment. The top of the table measures evenly to the top of the feet of the machine. I haven’t taken the table top lose yet, and tried to torque it with a ratchet or anything yet, but anyone have any suggestions for me?
    May 2011
    790
    Re: Squaring the x axis gantry
    You could shim it on one side.
    I have some stainless steel shim tape, it's great stuff. The kind I have is called "Matrix Super Shim Plus" and the website on it is Home
    Not sure if they are still selling it, but there are similar products to be found, just google "shim tape"
    Also, Misumi makes some wider stuff in different thicknesses, never used it.
    https://us.misumi-ec.com/vona2/detail/110300238820/
    Is there any adjustment in the way the gantry attaches to the riser plates? Can you think of a way to make some?
    Sep 2017
    7
    Quote Originally Posted by NIC 77 View Post
    It may be that I can get some .01” thick washers or shims and shim the entire right side of the table. I haven’t found any adjustment areas for that axis beam yet, all the screws are self scentering screws, and every time i loosen them to try to correct it, it just goes right back.
    Can you shim the table?
  1. Gantry squaring questions?
    By FelixPQ in forum DIY CNC Router Table Machines
    Last Post: 03-08-2016, 08:28 PM
  2. Squaring the Gantry to the X-axis
    By expo123 in forum Avid CNC
    Last Post: 11-09-2013, 01:25 PM
  3. Squaring a gantry - without a square?
    By Instance in forum DIY CNC Router Table Machines
    Last Post: 01-20-2011, 09:37 AM
  4. Squaring the gantry
    By bradbergemann in forum Excitech routers
    Last Post: 01-07-2010, 02:31 PM
  5. Squaring your Gantry, 1530 and similar.
    By Big S in forum Excitech routers
    Last Post: 04-15-2009, 10:23 AM
