586,108 active members*
3,038 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Who is using DMM drives and servos on their router?
    Jan 2013
    76
    Anyone on here using DMM dyn4 drives and servos on their router? I am at the point where I need to order either Teknic ClearPath units or DMM dyn4 drives and servos. I am leaning towards the DMM dyn4 drives because I can use 220 AC to power the motors. Eliminating the DC power supply for the motors.
    35538
    Re: Who is using DMM drives and servos on their router?
    I plan on using them, and bought one for testing before buying the 3 I need.
    The drive blew immediately when I fist powered it up. DMM repaired it for free, saying it was due to over voltage. They claim the drive is rated for 240V + 10%, but my voltage is about 245V.
    I plan on using a transformer to lower the voltage down to 220V, and to also use a line reactor as specified in the application note they sent me, attached below.
    My opinion is that an AC servo is actually much more powerful than the Clearpaths, as they have more torque at higher rpm.
    And the DMM's are actually cheaper than the Clearpaths, and about 25%-35% cheaper than other AC servos.
    Jan 2013
    76
    Thank you Gerry for the reply. It seems not many are using them as you are the only respondent. The DMM section on here isn't very active either so either they work great and no one is having any issues or they aren't that popular!
    15362
    Quote Originally Posted by Black Forest View Post
    Have been using Dmm for many years, there are a lot that are using them on the Zone, you will find a lot of Dmm Servo Drives and Motors being used by OEMs, YouTube has some users also
    They now have RS232/Modbus RS485/CAN Communication which puts them ahead of Most Servo Drives
    Mactec54
  1. Drives for large DC servos
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 01-14-2016, 01:17 PM
  2. Replies: 27
    Last Post: 03-10-2014, 08:02 PM
  3. DIY CNC with Industrial Servos & Drives
    By poldim in forum Servo Motors / Drives
    Last Post: 05-23-2013, 11:58 PM
  4. What drives/power for these servos?
    By bodini in forum Servo Motors / Drives
    Last Post: 01-03-2011, 09:35 PM
  5. servos, drives, p/s
    By scudzuki in forum Benchtop Machines
    Last Post: 02-09-2009, 01:02 AM
