586,121 active members*
3,190 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Conquest 42 Fanuc OT RS232 conversion to Ethernet or USB Is it possible?
Results 1 to 7 of 7
    Dec 2013
    5717
    I picked up a 1989 Conquest 42 with a Fanuc OT controller. I would like to replace the RS232 with USB or Ethernet connection. Is a USB serial port the best way to go? Rip out the Fanuc control and upgrade the system?
    Any ideas?
    Thanks, Jim
    Jim Dawson
    Sandy, Oregon, USA
    May 2016
    526
    Any ideas?
    Thanks, Jim
    Why don't you connect it to network via Wi-Fi
    Dec 2013
    5717
    Re: Conquest 42 Fanuc OT RS232 conversion to Ethernet or USB Is it possible?
    Quote Originally Posted by mbservice View Post
    Well, I do have Wi-Fi in the shop, how is it connected to the Fanuc controller?
    Jim Dawson
    Sandy, Oregon, USA
    May 2015
    70
    Check out http://www.highlanddnc.com/
    Dec 2013
    5717
    Quote Originally Posted by Mike283 View Post
    Thank you Mike. Exactly what I was looking for.
    Jim Dawson
    Sandy, Oregon, USA
    May 2012
    35
    Do not use Wifi in the shop. Use cable connections only. Try a device like Moxa Nport 5110 and convert your RS232 to Ethernet. Then you may use any DNC software with a virtual COM port on a computer.
    AGG Software. DNC Precision and CNC Syntax Editor software.
    Dec 2013
    5717
    Quote Originally Posted by HDowns View Post
    I do agree with you about having machine tools connected to a internet connected network; wired or Wi-Fi. My prefered file transfer method is by USB stick, keeps an air gap between the machines and the world.
    Having said that, what other objections do you have about using Wi-Fi in the shop?
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 5
    Last Post: 06-16-2022, 05:24 PM
  2. Replies: 4
    Last Post: 03-29-2014, 03:40 PM
  3. Conquest 42 OT RS232 port configs...after lightning
    By DOA in forum Hardinge Lathes
    Last Post: 08-15-2013, 01:12 AM
  4. Ethernet and rs232
    By 0alex in forum Haas Mills
    Last Post: 02-26-2010, 09:45 AM
  5. DNC over Ethernet/RS232 Terminal servers
    By tricky in forum DNC Problems and Solutions
    Last Post: 11-05-2005, 05:08 AM
