586,068 active members*
4,175 visitors online*
    Aug 2007
    224
    mold shrinkage
    4 seconds ago
    mold shrinkage value
    Can't understand how do I put these shrinkage value(see jpeg) on my model.. please any one guide me...0.0050cm/cm
    ....or 0.0050in/in...????what does it mean
    Regards
    Asif
    15362
    Re: mold shrinkage
    Quote Originally Posted by fsa View Post
    4 seconds ago
    Regards
    Asif
    It means that is how much the material is going to shrink, per cm or per inch, you will have to add this to your model, normally done as a percentage
    If you have a cavity that is say 4cm wide then you will add the material shrinkage number to that, but shrinkage will depend on your parts shape, the thickness of the part Etc, these numbers are just a starting guide, if you need a precise size, then you will have to run the part, then measure the part, and remachine the cavity to get the size you want, if your part size is not important, then just use the shrinkage they suggest and you will be close to the size you want
    Mactec54
    Nov 2012
    145
    4 seconds ago
    Regards
    Asif
    I would think that it is per inch using metric or imperial measurments.
    Aug 2007
    224
    Quote Originally Posted by tom o View Post
    Please check jpeg about what I understand...... a need a advice..about right or wrong
  1. Shrinkage rates for aluminum bronze?
    By Metzindustries in forum Casting Metals
    Last Post: 05-14-2017, 08:56 PM
  2. Aluminum shrinkage?
    By ZipSnipe in forum Material Machining Solutions
    Last Post: 11-28-2012, 12:36 AM
  3. Shrinkage in heat treat
    By vanm in forum MetalWork Discussion
    Last Post: 02-15-2010, 06:49 PM
  4. Shrinkage percentage
    By zeeshan.insight in forum Moldmaking
    Last Post: 06-21-2008, 02:56 PM
  5. figuring shrinkage
    By spock in forum Moldmaking
    Last Post: 06-14-2008, 04:31 PM
