586,052 active members*
4,294 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4th axis Identification. AC or DC
Results 1 to 6 of 6
    Dec 2015
    6
    I've been looking for a DC VH65 4th axis. When looking at the ID tags on a DC 4th is is listed as DC?
    All of the AC untis I have found all have an A/C stamped behind the model number. Can anyone confirm that if the Tag is not stamped A/C the unit is a DC model? If you have a DC unit can you post an image of what the ID tag on the end looks like?
    Thank you
    Peter Belfanti
    Belfanti Machine works.
    Sep 2009
    103
    Re: 4th axis Identification. AC or DC
    I don't ever remember seeing an AC or DC on the tag. The DC units have one large connecting plug while the AC have two smaller ones. Also, The DC motor cover Doesn't have a bump out on it where AC motor cover does.
    Check out these Photos; Notice the motor cover on the VH65 with the green tag. That's an AC. The other is a DC. Kinda hard to see the cables but you can tell by the cover.
    Dec 2015
    6
    Tedger,
    Thank you for the images. I must be blind, but I can't identify the the bump out you are talking about.. here is a few images of the unit I'm considering. can you share your thoughts? thank you so much for your time in helping with this!
    Sep 2009
    103
    Thats a DC unit. Note the one large plug that runs with the air hose for the brke.
    Here is a better picture of an AC. Note the L shaped cover and dual plug.
    Dec 2015
    6
    You are the best!.. and I must have been blind not to see the AC cover part. Thank you so much for your detailed and accurate knowledge!
    Sep 2009
    103
    No problem. Glad to help.
  1. Machine Identification
    By 526minis in forum Benchtop Machines
    Last Post: 09-25-2013, 04:05 AM
  2. metal identification
    By ihavenofish in forum MetalWork Discussion
    Last Post: 09-01-2011, 04:35 AM
  3. CNC identification
    By 777string in forum Benchtop Machines
    Last Post: 01-30-2010, 02:54 PM
  4. Bridgeport identification
    By unlock in forum Bridgeport / Hardinge Mills
    Last Post: 11-06-2009, 06:11 PM
  5. Boss 6 Z-Axis Pulley Identification / Problem
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 09-04-2006, 09:25 PM
