586,119 active members*
3,538 visitors online*
IndustryArena Forum > CAM Software > Vectric > Specific purpose for Vcarve
Results 1 to 9 of 9
    Mar 2004
    636
    With all of the wonderful features it seems that VCarve has built into it, I am trying to figure out if it can do a very simple function. I need to engrave with a stick type font as shown below. This is one of many files that I have in dxf file format that I need to cut. Is this to simple for v carve?
    Check out what I am working on at www.routerbitz.com!
    Apr 2005
    3634
    Like this?
    Aug 2005
    597
    Hi Hack,
    It should be very simple and straightforward to do this in VCarve Pro (as Switcher has kindly shown) and you can test the process using the Trial version.
    Open your DXF design
    Ensure the Size, XYZ origins and material thickness are correct
    Select the text to engrave
    Open the Toolpath Tab on the Right of the interface
    If the text is based on single stick / open vectors use the Profile Toolpath
    Enter the required Depth to engrave
    Select a suitable cutter
    Select the option to Machine On the selected lines
    Calculate
    Preview the toolpath
    Once you have calculated one of these toolpaths the settings become the default so engraving other plates gets even easier. Just select the text, create a new Profile toolapth and Calculate.
    Use the VCarving / Engraving Toolpath option if the text is based on closed fonts such as true type fonts.
    Enter a Flat Depth
    Select a cutter from the Tool Database
    Calculate
    Preview the results
    For reference - the next release of VCarve Pro includes a selection of different styles of Engraving Fonts so the design can easily be done inside the software. This is Version 4 and will be available around the start of May.
    I hope this all makes sense and let me know if you have any questions.
    Tony
    Apr 2005
    3634
    I attached the file I used from the screenshot in my 1st post.
    I used the trial version, so I don't know If you can use it or not. If you can, it will give you an idea how I put things together.
    I used an Arial font for all the text, & 3 rectangles (1 rectangle to underline "Caution").
    The screenshot below shows the order that I took after I finished my text & 3 rectangles.
    Your process will not be the same If you start with an outside DXF file.
    Total time was about 5min. with only VCarve Demo.
    Attached Files Attached Files
    Mar 2004
    636
    Got it Thank you
    Think I figured it out. Thank you.
    Dan
    Aug 2004
    3215
    Yup, you got it, pretty easy in the software huh?
    Apr 2005
    3634
    Quote Originally Posted by Hack View Post
    Dan
    Yours looks better than mine (rounded corners), good job.
    Did you use a DXF file, to start with?
    Mar 2004
    636
    Yes I did
    Yes I did start with a dxf.
    Dan
    Dec 2006
    775
    VcarvePro: creating rounded corner boxes
    I saw a tutorial that creates rounded boxes inside V-carve. You have to use the parallel line tool. Construct a parallel line using your box inwards. The distance you choose will become the radius. Now using that smaller box, construct a parallel line outwards with the same dimension. Delete the unnecessary boxes, keeping the rounded corner box.
    I just tried it yet, and it worked great.
    Dave
  1. coolant purpose?
    By jprobst in forum Haas Mills
    Last Post: 02-21-2007, 04:42 AM
  2. What is the Ideal, General Purpose Car???
    By HayTay in forum Community Club House
    Last Post: 08-07-2006, 11:07 AM
  3. Fit for the purpose (I think)
    By polus in forum DIY CNC Router Table Machines
    Last Post: 05-01-2006, 05:26 PM
  4. Purpose
    By kdoney in forum CNC Wire Foam Cutter Machines
    Last Post: 01-15-2005, 05:05 PM
  5. dual purpose cnc router
    By junkmail in forum DIY CNC Router Table Machines
    Last Post: 03-10-2004, 07:01 PM
