586,080 active members*
3,581 visitors online*
    Jan 2010
    36
    Question About Max Current for 100 watt laser
    I have a laser engraver on order with a 100 Watt RICI tube and would like to know what the optimum operating current would be. I understand that over driving the tine will cause early failure but what is the optimum current value.
    Tom
    Aug 2016
    75
    Re: Question About Max Current for 100 watt laser
    Look at your tube to get the model/series number. Then go to the RECI website and you will be able to look up the specifications for your tube.
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Feb 2015
    23
    I run mine at a maximum of 24ma. Yours might not be the same though.
  1. 700 watt fiber laser question
    By manakawari in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-01-2017, 12:51 AM
  2. Laser/Engraver Model CNCWL-1390N-80 Watt Laser
    By CNC-Warehouse in forum For Sale Only
    Last Post: 06-30-2016, 08:03 PM
  3. Replace 30 watt C series epilog laser with 60/55 watt C series tube
    By jrich in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-25-2014, 07:00 PM
  4. LTT 50 Watt Laser
    By cure1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2011, 11:35 PM
