586,069 active members*
3,596 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Power drawbar on a 1100 with BT30 spindle
    Aug 2007
    53
    Can't figure this out on the website. Has anyone got the 1100 with a power drawbar and the optional BT30 spindle. I know you can't have an ATC with that spindle.
    Sep 2009
    624
    Re: Power drawbar on a 1100 with BT30 spindle
    Quote Originally Posted by Dan2464 View Post
    Perhaps I'm wrong, having no personal experience with CAT or BT30 spindles, but my understanding is that these tooling systems are not compatible with a power draw bar of the Tormach design. No spring collet, so the up/down motion is no help. The Saunders R8 power drawbar design using an air tool to spin the drawbar might work.
    You might want to review the Tormach 1100 design white paper. I thought there was something there about using the 3/4" R8 collet vs the BT style tool holding. What I recall is that the 1100 is small enough that the extra rigidity of the BT style isn't much value, and the gain from fast tool changes is worth the trade-off. I had the impression that Tormach offered the BT spindle early on as a compatibility feature (if you had BT tooling already).
    Added: here's a discussion from another forum, but with several of our long-time (and expert) members weighing in. This is probably what I was recalling.
    https://en.industryarena.com/forum/b...es--97445.html
    Apr 2013
    1788
    The 770 manual (UM10350, chapter 8, page 146) says:
    "NOTE: BT30 Spindle Cartridge is not compatible with pull-stud type BT30 tool holders, power drawbar or automatic tool changer (ATC)."
    The PDB does not work with the BT30, I have seen a guy make a setup that did. I found it in a Google search.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
  1. Home made PCNC 1100 Power Drawbar
    By andyf97 in forum Tormach Personal CNC Mill
    Last Post: 03-05-2016, 01:37 AM
  2. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  3. Problem with my PCNC 1100 Power Drawbar
    By cobrakai in forum Tormach Personal CNC Mill
    Last Post: 09-03-2013, 07:16 AM
  4. PCNC 1100 with Power Drawbar for sale
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 11-14-2011, 10:27 PM
  5. Spindle upgrade and Power Drawbar
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 04-07-2011, 11:50 PM
