586,058 active members*
4,191 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > can you run G-code for other CNC using Pathpilot if G-code opens in Pathpilot?
    Jul 2008
    81
    Hello Forum,
    I am sorry if this is a dumb question. I had a Digital Wood Carver CNC router that used Mach 3. We sold it and I bought a 1100PCNC with Pathpilot. I have an engraved plaque/sign I made with the DWC I would like to make again and all I can find is the G-code from Mach-3 and the DWC. It opens fine in Pathpilot. But I do not know whether there would be other compatibility issues in trying to run the program with a engraving bit on my PCNC.
    I understand the Post Processors are different cause they are from different machines.
    Here is the header of the program.
    (BEGIN PREDATOR NC HEADER)
    (MACH_FILE=HAAS - 3XVMILL.MCH)
    (MTOOL T1 S7 D.25 H2. A60. C0. DIAM_OFFSET 1 = .125)
    (MTOOL T2 S1 D.25 H5. A0. C0. DIAM_OFFSET 2 = .125)
    (SBOX X-.8568 Y-1.0665 Z-.75 L11.1432 W4.9335 H0.)
    (END PREDATOR NC HEADER)
    O100
    (PROGRAM NUMBER)
    (PROGRAM NAME - AVRO-LOGO.GC)
    (POST - MACH 3 DWC)
    (DATE - FRI. 02/08/2013)
    (TIME - 03:20PM)
    N01 G20 G40 G49 G80 G90 G91.1
    (JOB 1 V-CARVING)
    (FEATURE V-CARVE)
    N02 T1 M6
    N03 M03
    N04 G00 G90 G54 Z.25 F25.
    N05 G00 X3.5813 Y1.8238
    N06 G01 Z-.19
    N07 G17 G03 X3.375 Y1.8295 I-.1041 J-.0345
    N08 G01 X3.247 Y1.5039
    N09 G17 G03 X3.3491 Y1.3541 I.1021 J-.0402
    N10 G01 X3.5849
    Goes on from here for hours.....
    Dec 2013
    5717
    Re: can you run G-code for other CNC using Pathpilot if G-code opens in Pathpilot?
    I would just run an air cut and see if it behaves. Just stay near the E-stop button
    Jim Dawson
    Sandy, Oregon, USA
    1943
    If pathpilot behaves like LinuxCNC on which it is based, opening the program should show anything in the G-code that it does not understand as soon as you open it. If that is successful, then it will likely run it fine, but as mentioned make an air cut above the table and keep an eye on it. Since the program was Mach3 compatible, I would suspect that there isn't anything in there that will give PathPilot a problem.
  1. PathPilot 2.x and PathPilot Simulator
    By draper-ballou in forum Tormach PathPilot™
    Last Post: 01-01-2019, 01:42 AM
  2. PathPilot 1.9.13
    By kstrauss in forum Tormach PathPilot™
    Last Post: 10-10-2017, 01:31 AM
  3. PathPilot™ v1.9.11 Now Available
    By David C. Allen in forum Tormach PathPilot™
    Last Post: 07-14-2017, 10:38 PM
  4. PathPilot v1.9.8
    Last Post: 02-01-2017, 09:50 PM
  5. PathPilot V1.6
    By adamboon in forum Tormach PathPilot™
    Last Post: 03-26-2015, 12:33 PM
