586,104 active members*
3,371 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Mini Mill Homing X Limit Switch Problem
    Aug 2005
    5
    Does anyone know just where to find the X Limit switch on the HAAS Mini Mill?
    I read that it's under a cover but have no idea what needs to be removed to even get at it.
    When doing a power up restart, the table travels all the way to the left hitting the end of it's travel and then generating an X Limit error code.
    I believe the problem to be a stuck or bad switch.
    HELP!
    Jun 2004
    6618
    Re: Haas Mini Mill Homing X Limit Switch Problem
    I haven't actually looked for it, but I would expect the home switch to be on the right side of the Y carriage under this long front cover attached to the table.
    Lee
    Aug 2005
    5
    It's actually on the back side in the middle of the table pointing up.
    There is a small ramp shaped sheet metal actuator on the right side of the slide which then contacts the switch when the table moves far to the left when homing.
    That piece had bent out of the way due to chip buildup that had accumulated under the cover since 2001.
    It was just a matter of clearing out all the crud, bending the actuator back into place and putting the cover back on.
    Problem Solved!
    Jun 2004
    6618
    Excellent.
    Glad to hear this. Good to know where it's at.
    Lee
  1. homing limit switch travel
    By tomcorden in forum Mach Mill
    Last Post: 12-24-2011, 12:46 AM
  2. A different type of homing/limit switch
    By nateman_doo in forum Benchtop Machines
    Last Post: 12-23-2011, 04:41 PM
  3. Homing and limit switch
    By shadowless in forum Taig Mills / Lathes
    Last Post: 09-19-2009, 01:26 AM
  4. what is the best homing and limit switch setup?
    By Bryscnc in forum Machines running Mach Software
    Last Post: 09-28-2006, 11:37 AM
