586,094 active members*
4,112 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Is this servo a good substitute for a milling machine spindle motor?
    Mar 2017
    98
    I have a RF-45 clone.
    https://tinyurl.com/yca3wpky or similar?
    I want to do a belt drive in my CNC conversion and I've priced vfd + induction motors at $350. For $500 a servo would seem more useful down the track, as well as a bit lighter.
    Any advice appreciated, thanks.
    15362
    Re: Is this servo a good substitute for a milling machine spindle motor?
    Quote Originally Posted by j3dprints View Post
    If the servo drive is good then it would work well, and a lot better than the motor they have, another one to look at is DMM, which may be a similar price better quality
    DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    The only thing you have to watch for is your voltage supply, servo drives are sensitive to over voltage, so something to check is your voltage and the Servo Drive requirement's
    Mactec54
  1. Is this cnc machine good enough for milling pockets into 10mm acryl?
    By KING2882000 in forum Want To Buy...Need help!
    Last Post: 10-12-2017, 04:33 PM
  2. Good budget CNC milling machine
    By mrroy76 in forum Want To Buy...Need help!
    Last Post: 04-12-2016, 07:01 AM
  3. Replies: 0
    Last Post: 12-04-2008, 09:36 AM
  4. Good base milling machine to add onto in future?
    By hansw3 in forum Benchtop Machines
    Last Post: 11-01-2007, 05:30 AM
  5. How to decide if an old milling machine is good?
    By crazyman in forum Knee Vertical Mills
    Last Post: 05-02-2006, 02:57 AM
