586,058 active members*
4,260 visitors online*
Results 1 to 5 of 5
    Dec 2003
    33
    Mach3 with ESS & 64bit
    Will a 64 bit version of windows 7 work in mach3 if I'm using an Ethernet smoothstepper ?
    Jun 2010
    4256
    Re: Mach3 with ESS & 64bit
    YES - based on personal experience.
    Cheers
    Roger
    Dec 2003
    33
    Are there any settings I need to adjust to make the 64bit version work or play well with others?
    35538
    Nope. Just don't install the parallel port driver when you install Mach3.
    I just completed a new screen set and I am looking for people to try it out
    Based on your setup
    "Will a 64 bit version of windows 7 work in mach3 if I'm using an Ethernet smoothstepper ?"
    You are the perfect setup.
    Are you interested?
    If so you can get it here.
    Licensing – nGeneYes, Inc – Software Working for Business
    If not no worries
  1. Best way to setup Mach3(or4) with Windows 7 64bit
    By Propwrench1 in forum Mach Software (ArtSoft software)
    Last Post: 09-07-2016, 08:17 AM
  2. Mach3 windows 7 64bit LPT PORT - BOB not working?
    By mrgame1988 in forum Benchtop Machines
    Last Post: 10-03-2015, 01:06 PM
  3. PARTMASTER V13 not installing on WIN 7 64bit
    By frankv1 in forum Dolphin CAD/CAM
    Last Post: 11-28-2014, 01:25 PM
  4. Windows 7 64bit - Mach3 - ugh, one more thing to deal with now....
    By airbrush in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2014, 08:14 PM
  5. MasterCam X5 on windows 7 - 64bit
    By pearldiver in forum Mastercam
    Last Post: 07-27-2011, 03:21 AM
