586,103 active members*
3,822 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Trying to cut o-ring grooves using a subprogram.
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Apr 2008
    24
    Re: Trying to cut o-ring grooves using a subprogram.
    the main risks are when it is not canceled before an absolute move
    Yup, been there done that! E-Stop has been my best friend!!
    Quote Originally Posted by DruMor View Post
    I cut o-ring grooves in some parts just yesterday. I use a macro routine to ramp in to depth. For what you are doing, how I would program it would be something like this:
    #1=0.(Starting depth)
    #2=.17(Z cut per lap)
    #3=-1.38(Final depth)
    while[#1gt#3]do1
    #1=[#1-#2]
    if[#1le#3]then #1=#3
    g2x-10.32i10.32z#1f125.
    end1
    Are these macros HAAS specific? I would love to have access to these conditional functions in our DMG... (while loop, if/then statements, etc.) We already have a lot of programs in our old machine written where the variables (#1, #2...) are specified on the first few lines, and it automatically calculates how to cut the part. For example I have a program to cut soft-jaws, where we simply specify width, length, and depth at the beginning of the program and it cuts whatever size soft jaw I needed. But there are some limitations currently the way I wrote them, for example depth must be divisible by 0.05 (otherwise depth of the two holes will be slightly off). When we move them I may rewrite them to be more efficient!
    Wallace
  2. #22
    Apr 2005
    713
    Quote Originally Posted by extanker59 View Post
    matt@RFR is right too about the complexity but I'm not a fan of going home after each groove. It would simplify everything though.
    I don't know if it's a setting or a control generation deal or what, but my 2007 VF-2ss ignores redundant tool changes. It's really convenient. My new Brother does NOT ignore duplicate tool changes so I had to change my sub program structure, but it's still not a huge deal.
  3. #23
    Oct 2017
    9
    No cutter comp used, center of the O-ring is the center of the cutter path.
  4. #24
    15362
    Quote Originally Posted by Geo55 View Post
    You should not need cutter comp, also when you cut Oring groves, you should use a regular endmill 3 to 5 flute, a ball endmill should not be used for Oring Groves
    Mactec54
Page 2 of 2 12
  1. Specifying V-Grooves
    By elfrench in forum Uncategorised CAD Discussion
    Last Post: 08-10-2013, 09:45 AM
  2. V Grooves!
    By granth3 in forum CNC Tooling
    Last Post: 10-18-2011, 10:19 PM
  3. What are Z grooves?
    By rezcar in forum Benchtop Machines
    Last Post: 12-12-2009, 08:13 AM
  4. Oil Grooves
    By gmilosevic in forum Want To Buy...Need help!
    Last Post: 02-24-2008, 12:03 PM
  5. Grooves MCX
    By jorgehrr in forum Mastercam
    Last Post: 04-18-2007, 09:58 PM
