586,075 active members*
4,078 visitors online*
Results 1 to 5 of 5
    Jul 2003
    162
    Switching from old parallel box to new controller
    I have an old 3 axis K2 stepper machine that uses a parallel port setup that I haven't actually used in years due to family stuff. That's all over with so now I can actually indulge in my hobbies again!
    The XP box is really flakey and I'd really like to switch up to newer hardware which means windows 10. I have a USB to Parallel adapter (used for programming atmel chips which I don't do any more) but from what I hear windows 10 just won't do the bit banging the way XP used. I'm also interested in adding a 4th axis so that pretty much dictates a new control setup anyway.
    What kind of options do I have to upgrade the control system?
    P.S. It'll be run from Mach3.
    Aug 2009
    655
    Re: Switching from old parallel box to new controller
    Look at the Centroid Acorn board. Windows 10 based and looks like a great little board. I don't use it but have used centroid in the past. I really really like the look of the new board and its very well priced.
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    35538
    A USB to parallel adapter won't work with any version of Windows, with Mach3.
    Avoid any Chinese Mach3 controllers.
    The most popular controller is the Ethernet Smoothstepper, but I'd recommend one of CNC Drive's controller, which work with both Mach3, and UCCNC. This gives you an option to move away from Mach3 for the $60 UCCNC license fee.
    Jul 2003
    162
    I went with a smoothstepper. Its pricier than the knock offs but it's rep is quite good. Thanks for the suggestion!
    Jun 2015
    943
    Quote Originally Posted by Rhodan View Post
    What Ger21 talked about are not knoff offs and they offer more options than the smoothstepper.
    What likely confused you is there are knock offs of the CNCDrive UC100 controllers which knock offs are chinese controllers and not real CNCDrive controllers.
  1. Need some guidance switching controller for AXYZ 5012 Table
    By muibubbles in forum Commercial CNC Wood Routers
    Last Post: 09-07-2017, 01:59 PM
  2. Switching Controller Board on Chinese 3040 or 3020 CNC Machine?
    By ColdSpike in forum USB, RS232, PARALLEL etc
    Last Post: 09-12-2015, 05:40 PM
  3. non-parallel CNC controller
    By vakeiros in forum Controller & Computer Solutions
    Last Post: 07-14-2015, 12:29 PM
  4. CNC 6040 5volts Switching Regulator on Parallel Pcb Blow
    By 2001cpx in forum Chinese Machines
    Last Post: 05-30-2013, 01:28 PM
  5. Parallel port controller
    By szynszyl in forum CNC Machine Related Electronics
    Last Post: 05-01-2007, 08:14 PM
