586,547 active members*
3,221 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMU-50 Evo Tool Change Recovery Procedure?
    Apr 2008
    24
    Hi folks,
    We are slowly bringing the DMU-50 online, last night during a tool change something doesn't sound right, and we hit the e-stop. Now I can't figure out how to get out of it. The two "flap" (rotating door) of the tool magazine is open, spindle is on top of tool pocket #2, and I can't get anything to move.
    I believe there is a magic switch inside the cabinet that I have to flip, which turns on a hidden tool-changer control screen on the controller, that allows me to manually move the spindle away and override/close the flap door. Does any of that rings a bell? The controller is a Heindenhain Millplus running software version v500.
    Thanks!!
    Wallace
    Apr 2008
    24
    Re: DMU-50 Evo Tool Change Recovery Procedure?
    1. Go to the "IO" screen (one of the soft keys on the bottom)
    2. Type in password 78900000 and then "Enter" (password will show up as "********")
    3. Right side soft-key changes to diagnostic functions
    4. Select Tool Changer
    5. Select Flap 1 Close
    6. Key in "0" and then "Enter" to exit diagnostic screen
    7. Back to chip-making
    Wallace
  1. mb66vb tool change procedure
    By deadlykitten in forum Okuma
    Last Post: 12-07-2016, 08:32 AM
  2. Fanuc 0i-TD tool change recovery stuck
    By PearcePump in forum Fanuc
    Last Post: 07-27-2015, 03:19 PM
  3. Fanuc 18-T Tool Change Recovery
    By TurnMyWorkpiece in forum Fanuc
    Last Post: 07-19-2012, 06:56 PM
  4. tool changer recovery
    By peakeng in forum Daewoo/Doosan
    Last Post: 03-06-2009, 08:58 PM
  5. Tool Change Recovery VF3 Umbrella
    By cncmaintenance in forum Haas Mills
    Last Post: 11-07-2008, 07:05 PM
