586,103 active members*
3,322 visitors online*
    Jan 2017
    28
    DIY Lathe Build Ideas
    Hello all,
    I am planing a future lathe build and wanted some input. Essentially, it has to do with the saddle mechanics. I was wondering if there are lathes or machines with so called "drive by wire" type handle mechanisms? Where there is no physical connection between the saddle handle and the actual feed shaft?
    The idea being that you turn the saddle handle as usual, it is connected to a rotary encoder which drives a stepper motor which does the actual moving of the saddle. And somehow, the saddle handle should be tight enough to simulate real life mechanical feedback.
    The reasoning behind it is that I would eliminate the extra gears to drive the feed shaft for auto cutting and allow for software control for cutting threads and other auto feed parts. Plus the feed shaft would be down the middle of the lathe, and not on the outside, although I suppose that's the least problematic.
    Any thoughts? How crucial is mechanical feedback on the saddle handle? What about backlash? Do you feel that you need that feedback to tell if you have chatter or other such problems?
    Mar 2004
    413
    Re: DIY Lathe Build Ideas
    There are OEM machines that have MPG wheels mounted in traditional locations, and do allow you to drive an axis both for set up and also mid job, all while the control automatically recalculates a running process (the brand I have witnessed doing this escapes me at the moment).
    On the DIY level, this individuals experience should be the center of great discussion in my opinion: http://www.cnczone.com/forums/bencht...rol-g0752.html
    I hope to utilize his methods on a lathe of my own, but I will have to learn a lot more about Arduino programming to use it as his code was dialed in around some rather specific brand unitized stepper driver/motors.
    Jan 2017
    28
    Quote Originally Posted by datac View Post
    Hi datac,
    Thanks for the link. I will check it out.
    As for Arduino, it is probably going to be the quickest way to get up and running. I myself use the TI Launchpad environment and their micro-controllers (think msp430 or the Tiva series of Cortex MCUs). I just wonder how to provide sensible feedback to the wheel.
  1. ideas for those trying to build '3d printers'
    By vacpress in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 08-10-2019, 10:21 PM
  2. Cartesian Robot CNC Build Ideas
    By KickFarter in forum DIY CNC Router Table Machines
    Last Post: 04-27-2015, 08:12 PM
  3. Need help with ideas for new build ($10-12k budget)
    By honestak in forum DIY CNC Router Table Machines
    Last Post: 10-10-2012, 12:48 PM
  4. New to CNC, want to build a prototype for ideas
    By Blindman17 in forum DIY CNC Router Table Machines
    Last Post: 05-10-2010, 04:53 PM
  5. Build Ideas needed
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 08-29-2009, 04:52 AM
