586,055 active members*
4,376 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Can Keizen foam be CNC cut with a mill?
    Jul 2013
    608
    hi guys, like the tittle says. If so can someone please recommend a tool bit?
    May 2016
    25
    Re: Can Keizen foam be CNC cut with a mill?
    Hi FoxCNC1,
    There is a guy on youtube, JOHNGRIMSMO, that was cutting foam on their mill. It might contain some good suggestions, if you haven't already found a solution. I think it was for their knife cases, but the idea is the same.
    Apr 2004
    5737
    Flexible foam is pretty much impossible to cut with an endmill; it just wraps up on the tool. You'd be better off using a hot knife mounted in the spindle (somehow - it might take machining a holder). Just remember to edit out the "M3" from your G-code, so it doesn't start to spin...
    You can get one here: https://www.fastcap.com/product/kaizen-foam-hot-knife
    Andrew Werby
    Website
  1. Foam CNC mill
    By WilliamWorkshop in forum CNC Wire Foam Cutter Machines
    Last Post: 05-05-2017, 02:53 AM
  2. Choosing which foam to mill
    By JackWilliam in forum CNC Machining Centers
    Last Post: 08-13-2013, 10:44 PM
  3. End Mill for foam ?
    By SScnc in forum Benchtop Machines
    Last Post: 12-04-2009, 04:15 PM
  4. soundproofing: 115 kilogram mill on foam ? Shacking mill ?
    By vroemm in forum Mechanical Calculations/Engineering Design
    Last Post: 05-13-2009, 11:02 AM
  5. Foam cutting mill
    By geostomp in forum DIY CNC Router Table Machines
    Last Post: 03-19-2009, 03:08 AM
