586,104 active members*
3,280 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > Dyna Myte 1007 Spindle motor and drive
Results 1 to 3 of 3
    Aug 2013
    5
    I know this may be a simple question, but I am a machinist and not a service tech.
    However,I did buy a 1007 and clean it up a bit for hobby stuff in my garage, and have no local
    service support available. So here's the question...
    Can I use any motor and drive combination provided the supplied voltage from the step up transformer is the same and the big board
    gets the information it needs?
    I heard there is a Dyna guru out here that might be able to help.
    Thanks, Stevie
    Oct 2017
    7
    I have a manual for my Dyna EM3116 which also claims to cover the 1007. The manual shows it as a 3-phase electrical. I had to rewire mine for use in my garage which only has 220V single phase. For the spindle motor, I inserted a solid state phase converter to get the 3-phase it wanted up to it. Worked fine. Cost new $110 off ebay in late 2017. You may need an electrician, technician, or engineer to help with the wiring if you aren't familiar with the differences. I'd be interested in hearing how your machine works out.
    Oct 2017
    7
    Sorry I didn't really answer your question. Specifically, the answer is probably no. The big board and the computer control wants a 110-120 volt single phase to properly run. At the factory, this was one phase split off from the 3 phase. So in your garage, you can split your single phase 220 to get the 110 volts. You can't just put a new plug on the end of the machine cord that goes to the wall plug and expect it to work. The motor should have a tag on it which will tell you the horsepower, voltage, and if it is single or 3 phase and how much current it might want. Your machine will have a contactor which the motor power goes through. You can send single or 3 phase through the contactor. So if you change the motor you can send the juice to the new motor through the contactor which the "big board" can control (switch) for you with an "M" command.
  1. Dyna Myte 2400 stepper motor board eeprom
    By ysihonda in forum Benchtop Machines
    Last Post: 01-30-2016, 03:17 AM
  2. dyna myte 3000
    By go0869 in forum Dyna Mechtronics
    Last Post: 10-04-2014, 08:16 PM
  3. Replies: 195
    Last Post: 03-02-2014, 02:17 AM
  4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
  5. DYNA MYTE PARTS
    By davidponte in forum Want To Buy...Need help!
    Last Post: 04-13-2008, 01:28 AM
