Hello,
I bought chinese cnc router 1325. It is cheep router with clasic steper motor. I upgrade it with serwo motors i bought recently. I have 750w motors with DELTA ASD A2 servos, and i need to insert correct electronic gear ratio so machine will work.
From suplier of machine originaly i get this calculation that i just put in nc studio and machine worked good:
x = 0,01042 mm/pulse
y = 0,01042 mm/pulse
z = 0,00625 mm/pulse
since i changed only motor and machanical things on machine was the same as before, can from this result be calculated electronic gear ratio that i need now?
Thank you for any help.
