586,061 active members*
4,414 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > GUIDE: How to clone your Mazak Fusion HDD for backup
    Sep 2006
    95
    Decided to make a guide on how to back up the hard drive of a mazak with the fusion control on it. these machines are getting old and hard drive problems are very common. make a backup of the hard drive on your machine before it dies. I saved myself $1900 by doing this and not buying one from mitsubishi.
    What you need:
    Another hard drive...I bought the exact same one my machine had in it on ebay for $40. You dont want to buy a huge HDD to put in this control. I dont think the bios will like it.
    44 pin IDE to USB adapter. This allows you to plug your hard drive into a usb port to access the files.
    http://en.community.dell.com/cfs-fil...dconverter.jpg
    Free software
    HDDGURU: HDD Raw Copy Tool
    All you do is hook the cable up to the drive, copy your machines drive to an image file and then write that on the new HDD. Save the image file just incase you need to make another copy someday.
    Its a straight forward process. Im posting this here because i want you guys to know this is possible. Mitsubishi did not lock the motherboard to the serial number of the hard drive. it might be locked to the volume serial number but the software copies that over. It copies the drives bit for bit and makes the partition exactly the same size.
    Im going to experiment with SSD drives next.
    Aug 2011
    27
    Hi, I have a problem with my lathe, its control is FCA635MNY. Could you send me the backup you made? It would be very helpful. Thank you.
    December 8, 2019 6
    Sep 2012
    216
    Quote Originally Posted by camarogod98 View Post
    What you need:
    Computers, Monitors & Technology Solutions | Dell USA
    Free software
    I know this is an older post but did you have any luck with the SSD. I have what seems to be a dead hard drive on my fusion 640 t and if I can recover the files I would like to use a SSD for future use
    Regards Bob
    Dec 2018
    Re: GUIDE: How to clone your Mazak Fusion HDD for backup
    Quote Originally Posted by sudsy View Post
    And now it's an even older post... I'm facing the same issue you were and would like to upgrade to a SSD. Did you have any luck?
  1. Backup windows Mazak QTN matrix controller
    By mazman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-14-2019, 12:44 AM
  2. Help me make a clone of my Fusion 640M Hard Drive
    By camarogod98 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-14-2018, 07:55 AM
  3. Mazak M32 system disk backup
    By sivaraj in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-25-2017, 10:41 PM
  4. MAZAK QT8 BATTERY BACKUP
    By nogginkj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-24-2009, 11:30 AM
  5. Mazak Fusion Parameter Backup
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2008, 05:42 PM
