586,512 active members*
3,548 visitors online*
Results 1 to 11 of 11
    Mar 2014
    1131
    Need help wiring the M16
    I just started to wiring my M16. I just need to know how to wire the RJ45 pins to the stepper driver. I simply don't know which pin from M16 goes where on the stepper driver. I wrote the pins bellow.
    Any help will be appreciated.
    Best,
    Suat
    Nov 2012
    1267
    Re: Need help wiring the M16
    STEP goes to PUL+
    DIR goes to DIR+
    ERR goes to ENA+ (or ENA-, depending on whether the error signal has positive or negative logic)
    GND goes to PUL-, DIR-, ENA- (or ENA+ goes to 5V instead)
    Mar 2014
    1131
    Quote Originally Posted by CitizenOfDreams View Post
    STEP goes to PUL+
    DIR goes to DIR+
    Thanks for your fast response.
    The pdf doesn't provide the info I need (or I don't see it). It just says ERR. So I don't know if it has positive or negative logic.
    Please see the page #8.
    http://cnc4pc.com/Tech_Docs/M16_R1.1_USER%20MANUAL.pdf
    Nov 2012
    1267
    Judging by the notation used in the manual, it's positive logic. You can try it both ways, it's not going to hurt anything.
    If the ERR signal is positive logic (0=OK, 1=error), then ERR goes to ENA-, 5V goes to ENA+.
    If the ERR signal is negative logic (0=error, 1=OK), then ERR goes to ENA+, GND goes to ENA-.
    Mar 2014
    1131
    Cool. Much appreciated. Thanks
    Nov 2012
    1267
    You are welcome, let us all know when you get it working.
    Mar 2014
    1131
    I have a new question. How can I connect a C3 indexing board to the M16? I have an encoder that I bought for the spindle but it's mechanically impossible to mount it to the spindle so I need to use my C3.
    Machine is a lathe by the way.
    Mar 2014
    1131
    @CitizenOfDreams
    I wired the drives as ERR positive logic but the steppers ran only one direction. So maybe it is negative logic? Or maybe I did the setup wrong? Tho, the plugin installer installs the all the settings as well as the plugin itself. I mean I didn't changed anything. Everything is supposed to work after the installation.
    Nov 2012
    1267
    If your steppers turn at all, then the ERR/ENA signal is connected correctly. Now you need to troubleshoot your PUL and DIR signals. Check if the DIR signal changes as you change the direction.
    Mar 2014
    1131
    How stupid I am. I noticed that I did the wiring wrong. I did it again and it worked.
    https://youtu.be/yFz9TU7pUo4
    By the way Johnny from cnc4pc sent me a wiring scheme. A little different. I don't know what it differs. Please see the attached image.
    Best,
    Suat
    Sent from my MI 5s Plus using Tapatalk
    Nov 2012
    1267
    Good to know you got it working!
  1. Replies: 0
    Last Post: 06-14-2017, 01:08 PM
  2. Replies: 19
    Last Post: 07-30-2015, 01:44 AM
  3. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  4. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  5. Wiring help!
    By WTX in forum Vertical Mill, Lathe Project Log
    Last Post: 02-03-2012, 11:22 PM
