586,103 active members*
2,767 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle just stopped spinning.... cnc
Page 1 of 2 12
Results 1 to 20 of 25
    Jun 2017
    238
    Hi I've been using my cnc for several months but today the spindle stopped turning mid way through a job.
    It uses a HY02D223B to drive the 2.2kw water cooled spindle. The vfd now reads:
    E.Lu.S
    I believe this is a power issue. Is this an easy fix or is it faulty?
    Jase
    Sent from my SM-G935F using Tapatalk
    Feb 2015
    Re: Spindle just stopped spinning.... cnc
    Found this on internet don know will it work for you also not it "google translation from Indonesian"
    Hello,
    Ane want to share how to solve error / fault E.Lu.S on inverter (VFD brand Huanyang).
    Ane had this error several days yesterday, and the reference to how solving it was quite rare, but simple bgt it .. so ane try to share here and mudah2an useful.
    The definition of error/fault according to the manual of his book:
    E: fault
    Lu: low voltage
    S: at stopping
    How to solve it:
    Step 1: setting parameters to factory default by way of,
    Pd013 = 08
    Step 2:
    Set value pd200 = 65535
    And
    Set value to pd209 = 50
    That's it !!Elus error solved!
    In the manual book no description for the parameter, krn function pd184-pd250 reserved.
    According to ane klo of its value, such as the maximum value of counting / counter 256 bit tp its function for what so, anyone know?
    Jun 2017
    238
    Quote Originally Posted by salamala View Post
    Hello,
    E: fault
    Lu: low voltage
    S: at stopping
    How to solve it:
    Pd013 = 08
    Step 2:
    And
    Thanks I'll try anything!
    15362
    Hello,
    E: fault
    Lu: low voltage
    S: at stopping
    How to solve it:
    Pd013 = 08
    Step 2:
    And
    It's never a good idea to change the factory codes, when a VFD like this has already been running for some time, there was something that caused this to happen, and needs to be solved before any factor codes are changed
    I have all of these codes, but would never post them as most would get in to a lot of trouble doing this, If the VFD had never run before then I would look at these changes
    Mactec54
    Jun 2017
    238
    Noted.
    Jun 2017
    238
    I have replaced my vfd and this was repaired. I've not wired it to anything but the mains and it comes up with error.
    I can't find what it is. Any ideas?
    24221
    Does it come up right away or after a short period?
    I take it you do not have a motor connected.
    Al.
    Albert E.
    Jun 2017
    238
    Al.
    Only the power cable is connected. When I turn it on If i remember rightly it displays 3 different codes. This being the last one.
    15362
    Quote Originally Posted by potts43 View Post
    How do you have it wired R S T and Ground connected
    What are the other codes ??
    EOH5 is over heating so something has happened to the fan or the temperature sensor
    Mactec54
    Jun 2017
    238
    I'll take a look and get back to you.
    Jun 2017
    238
    After turning the machine on. These are the errors.
    Jun 2017
    238
    Wiring.....
    ericks Guest
    Jase....i am sorry to hear that you having problems
    Jun 2017
    238
    Quote Originally Posted by ericks View Post
    Hi mate,
    This was my original vfd. Not the new one you helped setup. This was being repaired. I've just got it back and turned it on. It's not hooked up to my spindle. It was going to be an emergency back up if fixed.
    ericks Guest
    I can understand these cheap Chinese units giving problems. I opened up the 2.2 Kw unit i bought recently, the firmware is dodgy, the electronics although good quality is very basic in design/protection.
    They are still learning the lessons the main manufacturers/designers learnt long ago
    Jun 2017
    238
    If you get a minute I've uploaded the info you asked for.
    Cheers
    15362
    Cheers
    Your wiring looks fine, when you program this VFD Drive does the Parameters start with a PD then the number
    Looking at the faults you have there is something wrong with the input power module your repair guy must of not tested it to see it worked after he repaired it
    Mactec54
    Jun 2017
    238
    Yeah the programming is fine. I'll let him know. Thanks
    15362
    What I meant was I can tell what you have by what the Parameter letters are, if it is a genuine HY VFD or not, if yours Parameters start with PD---- if they start with PD then you have the real HY there are many copies that look just the same as the HY but are not, that is why I asked if your Parameters started with PD-----
    Mactec54
    Jun 2017
    238
    Yes mine start with PD.
Page 1 of 2 12
  1. Spindle won't start spinning on Multicam
    By lettersetc in forum EnRoute
    Last Post: 09-23-2015, 09:32 PM
  2. X6-1500GT - Spindle not spinning
    By Demanth in forum Chinese Machines
    Last Post: 11-22-2014, 05:11 PM
  3. Spindle spinning in reverse
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 09-29-2014, 02:39 AM
  4. How many rpm's is this spindle spinning?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2008, 08:40 PM
  5. Spinning a Bridgeport Spindle to 5-6K??
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 02-08-2006, 11:08 PM
