586,104 active members*
3,173 visitors online*
Results 1 to 7 of 7
    Jan 2016
    53
    Wood threading question (newbie)
    I'm new to lathes but have a need to do work on about 5/8 inch dia wood rods. I will need to be able to cut threads at the end of the rod. Never having done this before, should I be looking at a small hobby type of lathe to do this manually or opt for a machine that can auto-feed and cut the threads? Not having done this before, I'm thinking doing this by hand isn't the consistent way to be doing this? But maybe I'm wrong...maybe it can be done well manually?
    My budget is around 500.00 USD.
    Thanks for any advice...
    Re: Wood threading question (newbie)
    Apr 2004
    5737
    A regular wood lathe would also be unsuitable; there's no way you could ensure the threads were accurate. A 7x10 mini lathe would probably work to some extent; I think the through hole is about 5/8" (although it could be a little smaller, depending on the chuck) - or, as Ger suggests, something like that Beall jig, which accommodates several sizes of round stock.
    Andrew Werby
    Website
    Jan 2016
    53
    I'd like to be able to cut the threads on my own lathe vs having to buy another specialized thread cutting kit. The video did answer my question: hand feeding and turn the rod looks like a hit or miss situation. Maybe you just need practice some to be good at that. It looks like a lathe with an auto-feeder would work the best but I'm sure that adds to the cost of the lathe.
    Jan 2016
    53
    Quote Originally Posted by awerby View Post
    I am looking at a 7x10 mini lathe. I was unsure of how you actually cut the threads, but the Beall video made it clear it's a manual job unless your lathe has an auto-feed feature. Probably the mini-lathe's do not have that feature.
    Apr 2004
    5737
    The mini-lathes can cut threads, but for most pitches you'd need to invest in a set of change gears. Little Machine Shop has a handy calculator to figure out which gears you need in which positions to make a particular thread, depending on the pitch of your leadscrew: https://littlemachineshop.com/refere...ange_gears.php
    Andrew Werby
    Website
    Jan 2016
    53
    Thanks for those links. I did verify that the Harbor Freight 7x10 lathe does have an auto-feed to do threads. I'll probably end up getting one. Thanks.
  1. Just got me SPL..and question about threading
    By adamvs in forum Tormach Slant Lathe
    Last Post: 08-25-2014, 08:44 PM
  2. LB-15 Threading question
    By mbm in forum Okuma
    Last Post: 07-06-2010, 02:52 AM
  3. NEWBIE Question: ENGRAVING FOAM vs. WOOD.
    By cjchands in forum ArtCam Pro
    Last Post: 03-22-2010, 06:45 AM
  4. Threading Question
    By Dman65 in forum Mini Lathe
    Last Post: 08-07-2009, 05:00 PM
