586,100 active members*
2,615 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Shenhui 50 Watt Laser (Ebay) LED light no. 14 blinking , tube replacement
Results 1 to 6 of 6
    Feb 2013
    6
    Smile Shenhui 50 Watt Laser (Ebay) LED light no. 14 blinking , tube replacement
    Hi from Austria,
    running a 50 Watt China laser from Ebay (Shenhui blue-grey) I face the following issue:
    1., Does anyone know if it is normal that the LED no. 14 is blinking, what does it say?
    2., after only 4 months the tube (50watt/800mm) said "Good bye" without warning from one moment to another
    ok, that seems to be normal for that "reasonable model" but, can someone please tell me where I can get a new one,
    hopefully one which has a longer life?
    Many thanks in advance for your kind help.
    Manfred
    Feb 2010
    155
    Re: Shenhui 50 Watt Laser (Ebay) LED light no. 14 blinking , tube replacement
    Yes, my LED number 14 always blink. The printing on the controller says that number 14 is "Run".
    Do you have an ammeter (amp meter) on your machine? Is is possible that you were overdriving your tube? The maximum for these tubes is 18-20mA, which on my machine correlates to 65% power.
    Feb 2013
    6
    Thanks Robert for your reply.
    So that means the blinking led14 is normal.
    Unfortunately, I don`t have an ampmeter on my machine, but I did run the machine on minimum power 40 and maximum power 80 for a couple of weeks (cutting poplar plywood 4mm).
    Maybe that killed my tube. I didn`t know that.
    Greetings from Vienna, thank you again, Manfred
    Feb 2010
    155
    Check your water temperature as well.
    Feb 2013
    6
    Thanks Robert, the water temperature is fine, I believe, at highest below approx. 30 degrees celsius.
    Feb 2010
    155
    30 degrees Celsius seems high, but I guess it depends on your ambient temperature. The 30 degrees by itself shouldn't cause damage to the tube, but it does supposedly reduce the power output, which could have been causing you to overdrive the tube.
  1. Shenhui (RECI 150 watt tube) not going through entire tube. Sparks!
    By stonepercussion in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2017, 07:40 AM
  2. Shenhui 150 watt laser....Blowing fuses on the machine. Need some advise please.
    By ClickDraw in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2014, 09:29 AM
  3. Replace 30 watt C series epilog laser with 60/55 watt C series tube
    By jrich in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-25-2014, 07:00 PM
  4. 80 watt vs 60watt laser tube replacement
    By venturingraphic in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-22-2012, 09:04 PM
