I have a customer supplied drawing that is in .dwg format. The part is a print die that the font and format must match the print. When I open the drawing in Bobcad v27 the text no longer matches the original drawing. Also the text settings in Bobcad will not re-create the exact settings that are in AutoCAD. Is there another way to get around this problem. Attached is the original drawing in dwg and dxf.
