586,096 active members*
3,880 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Comments/thoughts on MX4660 wiring
    May 2016
    15
    Dear all,
    I am getting around to wiring up my steel gantry CNC router.
    Was hoping that someone would have a look at my wiring notes and provide feedback.
    Adam
    MX4660 Connected to Function Notes
    PINS
    20-60 VDC 48 V + (Power Supply, 12A) MAIN POWER Bridged to GND with 0.1F 100V CAP
    20-60 VDC 49 V + (Power Supply, 12A) Bridged to GND with 0.1F 100V CAP
    GND GND (Power Supply)
    CNC 3
    A+ A+ Stepper lead Stepper (X)
    A- A- Stepper lead NEMA 23 (5A)
    B+ B+ Stepper lead https://www.automationtechnologiesinc.com/products-page/nema-23/nema-23-three_eighths-inch-dual-shaft-with-a-flat-570-oz-in/
    B- B- Stepper lead
    CNC 4
    A+ A+ Stepper lead Stepper (Y)
    B- B- Stepper lead
    CNC 5
    A+ A+ Stepper lead Stepper (Z)
    B- B- Stepper lead
    CNC 6
    A+ Not connected
    A- Not connected
    B+ Not connected
    B- Not connected
    ESTOP + ESTOP switch Emergency stop
    ESTOP - ESTOP switch
    12V DC OUT 12V + (X endstops)
    OPTO 1 Not connected
    INPUT 1 X+ Endstop X+ Endstop
    INPUT 2 X- Endstop X- Endstop
    GND GND (X endstops)
    12V DC OUT 12V + (Y,Z endstops, height probe) power to Y & Z endstops and height probe
    OPTO 2 Not connected
    INPUT 3 Y+ Endstop Y+ Endstop
    INPUT 4 Y- Endstop Y- Endstop
    GND GND (Y endstops)
    INPUT 5 Z+ Endstop Z+ Endstop
    INPUT 6 Z- Endstop Z- Endstop
    GND GND (Z endstops)
    INPUT 7 Height Probe Touch off height probe
    INPUT 8 Not connected
    GND Not connected
    OUTPUT 1+ water pump relay Water pump control
    OUTPUT 1- water pump relay
    OUTPUT2+ cooling fan relay Cooling fan control
    OUTPUT 2- cooling fan relay
    OUTPUT 3+ Not connected
    OUTPUT 3- Not connected
    OUTPUT 4+ Not connected
    OUTPUT 4- Not connected
    OUTPUT5+ Not connected
    OUTPUT 5- Not connected
    OUTPUT6+ Not connected
    OUTPUT 6- Not connected
    10V + DC In 10 V power + Spindle speed control
    0~10V OUT VFD
    EGND 10 V power GND
    DB 25 Connector port 1 UCCNC 400 ETH
    Low Profile 26 pin port 2 UCCNC 400 ETH
    Nov 2015
    Re: Comments/thoughts on MX4660 wiring
    I have nearly the exact same setup sitting here on my bench. I am worried about hooking up the driver without the power shunt... I have used it a few times but I have never hooked a dedicated Estop button on the MX4660 due to the many posts of blowing the drive from back voltage coming in from the motors. I have been using the estop function in mach 3.
    Did you go with switching power units or a toroidal? my power supply has 2 80v 10000uF caps on the regulator and i think they will hold but I have put in a email to leadshine if I really need to implement the shunts.
    May 2016
    15
    Hi.
    I have 2 switching units.
    I did not get any feedback and have put this project on pause.
    This may help, I was told 10,000uF caps are pretty big and may be a big current draw during start-up so some sort of in rush current protection may be needed.
    As I understand you need either the caps or the shunt. The shunt is not cheap.
    I have to say I'm a bit pissed at Leadshine after paying $400 for the driver and there is not a better solution that they provide.
    All the best and look forward to hearing about what you end up doing.
    Adam
  1. MX4660 + wj200 wiring question - I'm SO close
    By blitz355 in forum CNC Machine Related Electronics
    Last Post: 06-22-2017, 03:41 AM
  2. MX4660 New Build.
    By indianad in forum DIY CNC Router Table Machines
    Last Post: 05-11-2017, 07:58 PM
  3. MX4660 kit
    By Bryan Rocker in forum Leadshine
    Last Post: 07-20-2015, 03:55 PM
  4. Replies: 0
    Last Post: 08-29-2011, 10:29 PM
  5. New CNC router build -- thoughts, comments, questions...
    By twry84 in forum DIY CNC Router Table Machines
    Last Post: 02-23-2009, 11:14 PM
