586,033 active members*
3,044 visitors online*
    Jun 2009
    110
    How does Mach 3 control a cnc4pc "C6" spindle speed controller?
    So after 6 years running my DIY Router I pulled the trigger and purchased a 2.2Kv spindle upgrade. Been very happy with it and been running from the VFD touchscreen. Decided to purchase a cnc4pc C6 spindle speed controller board since I have a older cnc4pc C10 breakout board. After reviewing the Mach 3 manual concerning spindle control I have a couple of newbie questions on how it functions. Hooking it all up is simple enough but:
    Do I simply start and stop the spindle from the Mach 3 screen Spindle icon as well as speed control?
    Or will the G-code file (I use RhinoCAM) start it for me for both start and speed setting. I'm confused concerning this issue. I have the Dwell for start and stop on the VFD set at 10 seconds which may be too long but its a place to start. Again I realize this is somewhat newbie but rather get some good advise before I make a mistake and smoke something.
    Steve
    Re: How does Mach 3 control a cnc4pc "C6" spindle speed controller?
    Both.
    If you just want to start it, you can click the spindle on/off button.
    If your g-code has an M3 in it, then that will also start the spindle.
    Same with rpm. You can enter it on the screen, or let the g-code change the speed with the S word.
    Jun 2009
    110
    Thank you for the quick reply!
    I do believe RhinoCam has both options. I know for sure it has the M3 but will check on the S.
    Steve
  1. Looking for some "high"er speed spindle ideas for my bf20 clone
    By GreatNorthGnome in forum Benchtop Machines
    Last Post: 06-28-2014, 08:57 AM
  2. Fagor error code " No Spindle Speed Value "
    By Hirro in forum Fagor Automation
    Last Post: 06-20-2013, 02:32 PM
  3. Machining "Speed Control" potentiometer?
    By declanhalpin in forum Gecko Drives
    Last Post: 04-24-2013, 02:32 PM
  4. "high" speed spindle with cad model
    By Thorpydo in forum Benchtop Machines
    Last Post: 04-21-2009, 11:38 PM
  5. My "Crazy" high speed spindle test
    By SScnc in forum Benchtop Machines
    Last Post: 04-21-2009, 01:16 PM
