586,112 active members*
3,070 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > 220/100 Volt non isolated power suplly for step motor drivers
    Jul 2003
    246
    My step motor driver work by DC 100V and all logic I/O pins of driver are optical isolated.
    I don't want to use line transformer for power supply. I can produce 100V DC from the direct hot line by step down type electronic regulator.
    At this condition: Any coils to earth voltage will be 220V.
    Stepper motor catologs give the dielectric strength value is 500V AC for one minute.
    Is it risk for human life if i use non isolated step down regulator ?
    Jul 2005
    442
    The coils will not see the full 220 (actually ~311 rectified) unless your switch element goes bad. I would put an overvoltge crowbar in for safety.
    Are you designing the switching regulator? if so, why not switch to an isolated design.
    Either way you need to be carefull with the wiring as 100V is considered a hazard isolated or not.
    Aaron
    Jul 2003
    246
    Non isolated switching regulators are simple and cheaper then smps. Therefore I want to use.
    Yes SMPS eliminate the isolation problem but this is second solution for me.
    I want learn the coil to motor body isolation is bad or good at the step motor?
    What does it means these?
    Insulation Resistance: 100M Ω Min. ,500VDC
    Dielectric Strength: 500VAC for one minute
  1. Power supply for 24 volt steppers
    By db113 in forum Stepper Motors / Drives
    Last Post: 04-23-2012, 12:35 PM
  2. Step Motor Driver and Power Supply Wiring
    By mcan in forum Open Source Controller Boards
    Last Post: 01-19-2007, 11:22 AM
  3. Step Motor DC Power Supply
    By BobWarfield in forum CNC Machine Related Electronics
    Last Post: 09-19-2006, 01:23 AM
  4. Electricity isolated from power-grid?
    By medved in forum Waterjet General Topics
    Last Post: 03-16-2006, 01:28 PM
  5. 24 volt dc power supply
    By natchez in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 06:31 AM
