586,065 active members*
4,842 visitors online*
    Oct 2007
    43
    Centroid Tool diameter offset
    Hi, When I program a small rectangle to be routed in a plastic product, the rout is bigger than I programed, as the bit is cutting on the center. I want the bit to be offset left. The manual says to use G41, and the cnc will automatically adjust over 1/2 the diameter of the tool. It says to use a D value. "if D001 is 0.5 and the job contains G41 D1, the software will adjust x and y positions 1/2 the diameter offset value to the left of the programmed tool path. Where can I adjust this? I see no D value in the g code. Any Ideas?
    Feb 2008
    280
    Re: Centroid Tool diameter offset
    Search the web for "CNC cutter diameter compensation". Any path that works on a Fanuc, Haas, Tormach, or whatever, will work on a Centroid control.
    A few basics:
    1) You need to position the tool somewhere off the part, preferably at the cutting depth, before you turn on compensation (e.g. with G41)
    2) After you turn on compensation, then do a lead-in move onto the part outline
    3) After you have gone all the way around the part, turn off compensation and do a lead-out move off of the part
    4) If your program does not have a D code (diameter offset index), then you need to put one in, with or before the G41.
    5) It is a good idea to use a D number that is the same as your tool number, but it is not required.
    6) The D number in the program is an index (from 1 to 200) into the Diameter offsets table
    7) The actual value of the tool diameter is stored in the Offset Library (on a Centroid, F1/Setup -> F2/Tool -> F1/Offsets)
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  2. Macro for tool diameter offset
    By allenp in forum G-Code Programing
    Last Post: 10-10-2018, 06:38 PM
  3. Centroid issue: Entering tool height offset library changes the Z value of my WCS
    By PhoenixMetal in forum Centroid CNC Control Products
    Last Post: 11-10-2017, 05:53 AM
  4. how to set tool diameter offset number
    By allenp in forum Haas Mills
    Last Post: 05-03-2016, 10:46 PM
  5. Hi all, Tool diameter offset question.
    By chad123 in forum Haas Mills
    Last Post: 03-14-2008, 08:02 AM
