586,068 active members*
3,706 visitors online*
IndustryArena Forum > CAD Software > Autodesk > F 360 Grid Disappears While in Model Mode
    Mar 2013
    344
    My Fusion 360 grid disappears while in Model Mode. To get it back I have to go to Sketch, Line, then quit Line. This will give me a grid for a few minutes then it goes away again. I find it really annoying. Is there a way to force it to stay?
    Re: F 360 Grid Disappears While in Model Mode
    At the bottom of the screen, there's an icon for grid and snap. Click on it, and check the Layout Grid checkbox.
    Mar 2013
    344
    Gerry,
    Thanks. It should already be checked, but I'll verify that it is. At least I was finally able to keep the sketch from jumping around. Its possible I inadvertently unchecked the grid.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Drilling popup screen disappears
    By Cutter7 in forum MadCAM
    Last Post: 03-02-2015, 11:17 AM
  3. Step Mode and Continius Mode exchanged
    By iron_aro in forum Mach Software (ArtSoft software)
    Last Post: 06-04-2014, 05:42 PM
  4. Part mode to assembly mode
    By Joesph Jackman in forum CamWorks
    Last Post: 12-21-2011, 07:41 AM
  5. Bridgeport Interact 2 -- tachometer mode vs. voltage mode?
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2010, 07:24 PM
