586,307 active members*
2,966 visitors online*
Results 1 to 7 of 7
    Apr 2004
    326
    Contour tab "witness lines" ?
    I'm seeing these "witness lines" or artifacts from when I cut a profile with tabs. In this picture, they are more visible due to burning but that is not always the case. My instinct is to attribute it to Z-axis tramming, but I can't get my head around that. If biased, the up/down during tabs should still follow the same lines as the regular cut.
    Any ideas? These are with both 1/4" and 3/8" compression bits.
    Thanks.
    Attachment 381784
    Jan 2015
    194
    Re: Contour tab "witness lines" ?
    Do you have the ability to do 3D tabs, which can be done in Vcarve? Essentially, instead of a straight up/down Z move, which means the bit spins in one place longer, the 3D tabs are a triangle so the bit is still moving forward while raising up/down.
    Apr 2004
    326
    Quote Originally Posted by dgage View Post
    Yes! F360 has an option for that in tab setup. I'll have to give it a try and see what happens.
    Thanks!
    PS. Anybody else getting an annoying ad page re-direct to Chevy when hitting "reply with quote"? Happened twice.
    Mar 2005
    109
    Quote Originally Posted by Kosh View Post
    No
    Apr 2004
    326
    Just tried it today, it didn't really help. Still seeing those lines.
    Jan 2015
    194
    Take a look at the second post in this thread as he talks about why you’d use a last pass (allowance) to clean up machining marks. His second paragraph covers cut direction, which is another variable you could try along with the last pass allowance. has these settings since they’re fairly basic.
    Vectric Forum ? View topic - separate last pass
    Apr 2004
    326
    Oh, I am already doing a finishing pass.
  1. Replies: 6
    Last Post: 01-23-2021, 04:53 PM
  2. problem "lag" on k40 speed slows down on some lines engraving halftones image
    By hargossath in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-22-2016, 07:20 AM
  3. Video Tutorial Of "OPEN CONTOUR CUTTING"
    By Ajancnc in forum Videos
    Last Post: 01-13-2015, 04:31 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Teach me how to "Group" entities and lines
    By fretsman in forum Autodesk
    Last Post: 12-31-2007, 10:18 PM
