586,082 active members*
3,826 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan 2600y y axis cutter comp question
    Nov 2006
    59
    I have doosan 2600y with a fanuc 31i control. I programmed to interpolate a bolt circle on a flange using the x and y axis. When I run it without comp everything is fine. When I put a value in the wear offset to make bring the holes to size the center of the hole actually shifts in the x axis twrds the center of the part. I'm new to lathes with live tooling, am I missing something?
    Oct 2009
    42
    Re: Doosan 2600y y axis cutter comp question
    I'm not familiar with the fanuc control but I would assume that you need to adjust the wear for the tool diameter instead of wear for the X axis?
    Sent from my SM-N910V using Tapatalk
  1. cutter comp question
    By joeyjrc in forum Tormach Personal CNC Mill
    Last Post: 02-01-2015, 05:27 PM
  2. Milling cutter comp question
    By shags72 in forum Okuma
    Last Post: 10-13-2013, 06:53 AM
  3. Doosan Lathe (Fanuc control) Cutter Comp
    By Hkirchoff in forum Fanuc
    Last Post: 06-28-2012, 12:08 AM
  4. Cutter Comp Question
    By behindpropeller in forum Haas Mills
    Last Post: 12-25-2009, 06:21 AM
