586,058 active members*
4,613 visitors online*
    Sep 2008
    148
    Gecko G540 Wiring
    Does anyone have a wiring diagram that is colour coded that I can use to wire up my G540? I'm using a DPST switch on the Front of the case along with an NC E-Stop Switch. A 36V Power Supply with a 3-in-1 Inlet Module Plug 5A Glass Fuse Rocker Switch Red Light 3-Pin IEC320 C14 Male Power Socket Screw Mount and a Gecko G540. I have the Homing Switches figured out along with a Touch Plate but am confused about wiring from the 3-in-1 Inlet Module Plug to the power supply and the G540. I had a Standard Inlet Module but had a Short that luckily didn't destroy my G540 and decided to go with one that was screwed into the case along with a Fuse.
    My main concern is getting the connections from the Inlet Plug Module to the Power Supply and the DPST Switch.
    Dec 2017
    82
    Re: Gecko G540 Wiring
    if you still have problem with gecko , I can work for you online to fix that.
    email me [email protected]
    Sep 2008
    148
    I received assistance from Vince at eDealers Direct on eBay as he sells these professionally. He made me aware of the fact that running 2 On/Off Switches would be rather Redundant seeing as the Input Module has both a Fuse and a Switch.
  1. gecko g540 and mach3 wiring and settings
    By blackdoglaser in forum Gecko Drives
    Last Post: 08-17-2016, 07:59 PM
  2. Taig and Gecko g540 wiring questions
    By NicolasArg in forum Taig Mills / Lathes
    Last Post: 04-29-2016, 05:58 PM
  3. Gecko G540 DB9 to bipolar stepper wiring
    By groos in forum USA Club House
    Last Post: 10-19-2014, 10:09 PM
  4. Wiring Gecko G540 to PSU
    By rnm85 in forum DIY CNC Router Table Machines
    Last Post: 01-08-2012, 02:48 AM
  5. Minimum wiring connections for Gecko G540
    By CNC Lurker in forum DIY CNC Router Table Machines
    Last Post: 12-09-2011, 10:30 PM
