586,036 active members*
3,695 visitors online*
Results 1 to 12 of 12
    Jul 2016
    13
    Lightbulb lichuan closed loop
    hi evry one i have 4 of lichuan closed loop https://www.aliexpress.com/store/pro...5bdadf473tkD2E
    can you help me for chose the right power supply?
    and how to work with this https://www.aliexpress.com/item/debu...86dcea5a&tpp=1
    Feb 2007
    4553
    Re: lichuan closed loop
    Something like this would be a good solution>
    PS-15N80 - 1500W 80V Power Supply - AnTek Products Corp
    Quote Originally Posted by habibmgh View Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2016
    13
    80v isn't too much
    and how much Amps for all 4?
    the one consume 7.5Amps
    Feb 2007
    4553
    The amperage requirement would be 2/3 of the total amp draw of the combined motors.
    I would email the manufacture and confirm the suggested optimal power supply voltage.
    Higher voltage will enhance the r.p.m. range of the motor.
    Jeff...
    Jul 2016
    13
    what about this power supply https://www.omc-stepperonline.com/po...-s-350-60.html
    i will use 4 of theme one for eatch stepper
    am i right?
    Feb 2007
    4553
    That is cutting it very close, I have no idea if durability will become an issue in the long run.
    Have a most awesome New Year!
    Jeff...
    am i right?
    Jul 2016
    13
    Feb 2007
    4553
    Yes
    Jul 2016
    13
    is it safe or not?
    explain to me pls
    Feb 2007
    4553
    An ac power source "20~70VAC" is the stated manufacturer's specification 48 VAC is safe.
    Jul 2016
    13
    hi Jeff i'm sorry i have lot of questions for you would help me
    I have 2 of 36V 10A power supply. can i connect them to have 72V 10A power supply like that
    http://www.cnczone.com/forums/attach...d=383284&stc=1
    Feb 2007
    4553
    Exclamation Be Very Careful
    Be extremely cautious connecting the power supplies in series since they are switching power supplies, many times they will not play well together.
    The capacitors inside the power supplies most likely are not rated anywhere near 70 volts.
    The electrolytic capacitors can explode violently if the operating voltage is exceeded!
    Also If the commons of the power supplies are at ground potential it will not work.
    I would not recommend doing so without a good understanding of such matters.
    Jeff...
  1. Closing the loop with Path Pilot. Possibly dual (global) closed loop?
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 05-04-2016, 09:39 PM
  2. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  3. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  4. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
  5. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 05:30 PM
