hello pls, is there a system variable for rapid droop ( like vinp* ) ? attached image
and what are these :
... VIPXD, VIPXE, VIPXF : Droop amount in XD-axis ( XE , XF)
... VIPZD, VIPZE, VIPZF : Droop amount in ZD-axis ( ZE , ZF ) ? kindly
Nope. Not that I've ever heard about.
Experience is what you get just after you needed it.
hey mr Wizard i have runned some trials ( tring to reduce indexing time + others ), but i could not reduce program time by using "droop" and/or "rapid droop"
it seems that lathes are moving as fast as possible, without messing with those droops ( probably thats why G64 is default, and also "rapid droop" is disabled )
"rapid droop" = "droop" only when a rapid is involved, and allows a larger ipw (=10mm); how my clearances are pretty low ( 1-2.5mm at toolpath begin, and 0.3mm at toolpath end ), i think i dont need "rapid droop" / kindly
