586,494 active members*
2,629 visitors online*
Page 3 of 3 123
Results 41 to 43 of 43
  1. #41
    Jul 2003
    1220
    Tom
    Version to suit your lathe attached.
  2. #42
    May 2021
    Re: How to correctly chamfer a hole?
    Quote Originally Posted by Kiwi View Post
    JWK42
    Altered program to enable save to notepad.
    In 2021 gonna use it. Have ou improved it or smth?
  3. #43
    Jun 2015
    4154
    hy if this popped up, then i have solution for okuma, written last year, to use a countersink on C or Y axis
    infos :
    ... uses a linear corection parameter, so to reduce chamfer height variations
    ... segmentation can be controlled, so to avoid succumbing the machine with all those small movements
    ... compares real process time with estimated time, in order to detect if cnc was succumbed or not
    ... linear or procedural code
    ... uses HiCut-Pro
    ... to make it rough, simply change the inputs and raise X
    * chamfer height variations are increasing with overall CorY axis travel, thus the bigger the hole and the smaller the part; if needed, custom corection function can be implemented
    after i tuned it to look nice, considering that only a chamfer was needed, i simply speed it up by making it poligonal, thus reducing the number of segments; if you focus your eye, you can see those segments, but it doens't matter for the end purpose / kindly
Page 3 of 3 123
  1. Chamfer hole located on an angled
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 04-17-2014, 08:34 PM
  2. Cross Hole Chamfer (G16? G12.1?)
    By Ovrclck350 in forum CNC Swiss Screw Machines
    Last Post: 02-14-2014, 04:32 PM
  3. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  4. CHAMFER FOR TAPPED HOLE
    Last Post: 07-03-2012, 09:11 PM
  5. Depth Calculator - Chamfer a hole
    By jcnewbie in forum Mastercam
    Last Post: 10-23-2009, 11:55 PM
