586,043 active members*
3,782 visitors online*
    Jan 2014
    5
    K2 CNC 1045 V.2
    Hi, I'm trying to get a K2 CNC 1045 V.2 running using mach 3. we've got the endstops and the e-stop working, but we're having trouble with getting the motors to turn. currently, when the controller is powered on, the steppers lock and whine. I'm assuming this is normal? also, i'm not sure which pins on the parallel port are assigned to which motors. I turned off everything except the x axis in mach 3 and tried all possible combinations of pins 2-9, with no luck. could it be that i'm using a store-bought printer cable instead of a parallel cable with a null modem? is a null modem required for this? any advice is hugely appreciated!!
    thanks in advance!
    Jun 2005
    1730
    Re: K2 CNC 1045 V.2
    These are the most common assignments
    Pin2 Step X
    Pin3. Direction X
    Pin4. Step Y
    Pin5. Direction Y
    Pin6. Step Z
    Pin7. Direction Z
    Russ
    Jan 2014
    5
    Quote Originally Posted by CNCMAN172 View Post
    Pin2 Step X
    Pin3. Direction X
    Pin4. Step Y
    Pin5. Direction Y
    Pin6. Step Z
    Pin7. Direction Z
    Russ
    Thanks! I'll give that a shot tomorrow.
  1. MILLING GROOVE IN 1045 STEEL WITH TINY TOOL
    By NIRAV1OO7 in forum G-Code Programing
    Last Post: 04-12-2014, 01:48 AM
  2. MILLING GROOVE IN 1045 STEEL WITH TINY TOOL
    Last Post: 04-11-2014, 01:13 PM
  3. GROOVING IN 1045 STEEL CNC MILLING
    Last Post: 04-11-2014, 12:44 PM
  4. 4140 vs. 1045
    By mmerriman in forum Material Machining Solutions
    Last Post: 03-25-2009, 11:00 AM
  5. 1045 precision ground shaft deflection
    By elogicca in forum Mechanical Calculations/Engineering Design
    Last Post: 02-06-2007, 08:14 PM
