586,105 active members*
3,320 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Anyone use a vacuum chuck?
    Dec 2009
    594
    Question Anyone use a vacuum chuck?
    When I bought the NM200 in 2010, I stupidly asked for the tall column version, thinking that I'd magically get more Z travel along with Z space. The result of this version is that the spindle can't get close to the table, or even to a vise on the table. Luckily I owned a 8" tilt table, and with access to surface grinder at school, I was able to grind the top and bottom flat and parallel. With this table mounted to the Novakon table and a Kurt vise on top, I've been able to get along nicely as long as the stock isn't too big. For stock much longer than the vise's 6", I've been using a pair of 12" soft jaws from Monster Jaws.
    The spindle nose still can only get to about 2.5" above the tilt table, so today's project was to raise it by 2" using a pair of 2-4-6 blocks.
    I intend to mount a vacuum chuck from Pierce Workholding in order to machine some sheet material. Which brings me to the point of this post.
    While the items I'm cutting from the sheet need to be through cut eventually, I can't do so without releasing the vacuum. So I need a target depth just less than the material thickness. How little material can I leave without causing problems? Stock is aluminum from 1/8 to 1/8 thickness, and acrylic 1/8 and 1/4.
    Dec 2009
    594
    Re: Anyone use a vacuum chuck?
    I finished my first parts today using the chuck. Stock was 12x12x.236" sheet acrylic. I set final depth as .01" above the chuck surface, and the result was that the parts were easy to extract from the sheet and deburr with a small deburring knife.
    Here's the setup prior to machining:
    Oct 2011
    61
    Thanks for posting your setup. I’m considering something similar for my machine.
    CJ
    Sent from my iPad using Tapatalk
  1. MDF Vacuum not working - Adding holes to strengthen vacuum
    By TheHiggsBroson in forum WoodWorking Topics
    Last Post: 05-09-2017, 05:55 PM
  2. Anyone Ever Made A Vacuum Chuck?
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 01-18-2013, 01:02 AM
  3. Turning rounter chuck into a blower/vacuum?
    By strangetanks in forum DIY CNC Router Table Machines
    Last Post: 01-02-2011, 07:57 PM
  4. Vacuum Chuck/Table Creation QUestions
    By MidFloridaTech in forum MetalWork Discussion
    Last Post: 02-26-2008, 12:28 PM
  5. Haas Control and Vacuum Chuck
    By big_mak in forum Haas Mills
    Last Post: 10-01-2007, 07:25 PM
