586,419 active members*
3,329 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo equivalent to Stepper Help
Results 1 to 11 of 11
    Dec 2006
    947
    I'm planning a CNC router 4' x 8' build and loved the features of the DMM servos I used on my Mori Seiki Lathe Rebuild. So I was thinking a stepper in the 900-1200 oz in range would work for my design. What servo would I need that would compare to that?
    Re: Servo equivalent to Stepper Help
    It's not that simple.
    It depends on how fast you'd be spinning the stepper, and the servo.
    A 1200 oz stepper probably has maybe 400oz of torque at 500rpm, and about 150oz at 1000rpm.
    A 400w DMM servo has 170oz of torque at 3000 rpm. If you gear it 3:1, that's over 500oz of torque at 1000rpm, or about 3x that of the stepper. And the Servo has a peak torque about 3x higher, so for short bursts, like during acceleration, it can be nearly 10x more powerful than the stepper.
    Depending on how much weight you are moving, and how fast, the 750wmay be a better choice.
    Dec 2006
    947
    Ok thanks. Yeah I'll probably be doing a 3:1 ratio or more. Not sure how heavy the gantry would be; haven't gotten that far.
    15362
    Quote Originally Posted by Cartierusm View Post
    750w to 1Kw depending on your machine build
    Mactec54
    24223
    Mori Seiki often used Fanuc systems, what size motors were on there originally?
    Al.
    Albert E.
    Dec 2006
    947
    Hmm if I go that big I'm getting into some cost. I don't mind using steppers; I have steppers on most my machines, but what I was aiming for with the servos was accurate homing.
    With the DMM you can set a function to have the servos home to index zero on it's own encoders so I'm dead accurate right from the start. This is necessary on my lathe.
    Are there any options for accurate homing with steppers? In the past I found that limit switches are just not that accurate. I guess one way would be to use a fixed block near home on the machine and on every start up use my Haimer 3D sensor to set zeros on my axis so any fixed jigs would be in the same position.
    Dec 2013
    5717
    Why not use linear encoders on the axes? That way they will work with servos or steppers and homing is not dependant on limits. However, using proper limits, the positioning can be very accurate also.
    Jim Dawson
    Sandy, Oregon, USA
    Mount an encoder to the shaft, and you can home to the index, just like a servo.
    Or simply buy better home switches.
    Dec 2006
    947
    What homing switches do you recommend?
    Dec 2013
    5717
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2006
    947
    Thanks. I'm amazed that I haven't come across those before. I use automation direct a ton. I'll try that.
  1. Pulse equivalent
    By sunstream in forum Excitech routers
    Last Post: 04-05-2020, 05:09 AM
  2. Milling equivalent of G71
    By scrapper400 in forum G-Code Programing
    Last Post: 12-03-2008, 06:02 PM
  3. Replies: 8
    Last Post: 06-24-2008, 06:20 PM
  4. Equivalent servo system of step motor
    By bunalmis in forum Servo Motors / Drives
    Last Post: 11-23-2006, 12:33 AM
