586,068 active members*
3,876 visitors online*
Results 1 to 7 of 7
    Mar 2017
    181
    Help with a Spoilboard Grid
    I want to make a Grid on my spoilboard but I can't seem to control the Depth of a V-Bit.
    Any "words of wisdom" here?
    Maybe I'm going about it the wrong way so...set me straight!
    Dec 2013
    5717
    Re: Help with a Soilboard Grid
    Assuming your Z is not moving while cutting, is the spoil board laying flat on the table?
    Jim Dawson
    Sandy, Oregon, USA
    You need to tell us exactly what you are trying to do.
    Meaning how are you programming the toolpaths?
    Mar 2017
    181
    I thank you guys fr responding, both of you.
    I have designed a GRID in Vectric Aspire and am outputting in Mach3. My issue is setting the depth in the toolpath, I want the GRID to be very shallow, maybe 1/16th inch. From all the YouTube videos I've seen I don't understand how to do that.
    The spoilboard has been surfaced and te router has been recently tramned. It is pretty darn flat to begin with.
    Can I use a 60 degree bit or do I need a "skinnier" bit?
    Dec 2013
    5717
    A 60° bit will give you a width of about 0.072 wide at 0.625 depth. Not sure what you are really asking here. Do you want the width wider than that?
    Jim Dawson
    Sandy, Oregon, USA
    Re: Help with a Spoilboard Grid
    In Aspire, use a Profile Path, ON the vector, with your V Bit. Just tell it the depth you want.
    Mar 2017
    181
    PROFILE...now I understand. I was using the "VCarve" setting & like Gary said it was way too deep.
    I'll try it in a few minutes! Thanks again guys!
  1. GRID IN V27
    By RAF. in forum BobCad-Cam
    Last Post: 09-11-2014, 07:25 PM
  2. Grid Shift
    By scuba in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2013, 02:10 PM
  3. Grid
    By craig in forum Mastercam
    Last Post: 06-20-2008, 04:55 PM
  4. CNC off the grid.
    By grinderdust in forum Environmental / Alternate Energy
    Last Post: 12-09-2007, 09:58 PM
  5. no grid ??
    By chrisw765 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-18-2005, 06:59 AM
