586,089 active members*
3,709 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Simulator cell and voxel size issue.
Results 1 to 8 of 8
    Jan 2017
    7
    So someone (me) might've (definitely) messed with the cell and voxel size in the simulator and now it either looks big and chunky when simulating or crashes if I adjust the size too much. There's a good chance they (I) might not truly understand the settings like they (I) thought. Any suggestions would be greatly appreciated!
    Apr 2003
    1357
    Re: Simulator cell and voxel size issue.
    What version are you using?
    Jan 2017
    7
    I'm using version 5
    5.0.2017.1031 (Prerelease)
    Apr 2003
    1357
    The simulator is not ready for actual use in these pre-releases. We have pre-releases because Microsoft's flakey Windows10 updates breaks software. Joakim had to release what he's working on so his customers would not be without madCAM.
    Dan
    Jan 2017
    7
    Ok that makes sense. Thanks
    Feb 2012
    30
    I have been struggling to get my simulator working satisfactorily after downloading the March release for 5.0. The simulation for this latest version was so full of artifacts and had such poor resolution that it wasn't worth using. I went back to the Oct 2017 version, which did work, but it did not have the same quality of rendering in the simulation as it did before installing the March 2018 release. I have been using it regardless but very disappointed in the quality. This afternoon I found the advanced tab under the simulator settings, and started playing with the Cell option. I dropped it down to 0.1 and was getting quite good quality to the rendering of the simulator. I should have stopped there, but I thought, "Hey, maybe I can tweak it a bit finer yet." So I changed the cell size to 0.01". That was a mistake. The simulator now just hangs, when I load it. It doesn't even show the stock, and I get a Not Responding message from Windows. I have uninstalled MadCam, gone forward and backwards with versions, but I cannot get the Simulator to load without hanging. Apparently, this information is stored somewhere in a configuration file that is not deleted when MadCam is unstalled. Any help would be appreciated!
    Ken
    Apr 2007
    5
    Hello KennethC,
    I am NOT sure if this might help, but try Regedit for CURRENT user and find this:
    HKEY_CURRENT_USER\Software\5xcnc\5.0\Plug-ins\da262747-63d5-4f50-ba03-b7c4f4486737\Simulator Settings
    Perhaps da2627... might be different for you
    Then in the right pane there are different Simulator Settings and corresponding values, among other for CellResolution and VoxelResolution
    Hope this can help you
    Regards
    Feb 2012
    30
    Quote Originally Posted by gopal View Post
    Hello KennethC,
    Regards
    That worked! Thanks Gopal
  1. CO2 Laser cut SIZE issue.
    By Satvinder in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-18-2017, 05:38 AM
  2. Fusion 360 text size issue
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 07-21-2016, 06:39 PM
  3. Tebis, issue with simulator
    By coutros in forum Uncategorised CAM Discussion
    Last Post: 04-23-2012, 04:57 AM
  4. Ordering honeycomb ( what cell structure size?)
    By AustinT in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2010, 06:20 PM
