Fella's
I have another newbie question. I finally got everything wired up and installed on the Saturn 1 setup. I was able to connect to the smoothstepper from the computer, I loaded the pre made XML configs for one of the CRP 4x4 "pro" kits into Mach3. I can get the display window and the DRO's to jog in Mach3 but there is no motor movement on any of the steppers.
I checked the emergency stop and the "motor control" toggle on the enclosure. I checked that none of the limit switches were triggering manually by holding metal up to each and seeing each clear. I am able to connect to and ping the smoothstepper.
I am sure this is something simple that I am missing. any ideas on what to check next? I put in a request to CNC Router parts, but no one called me all day today.
Thank you for your help.
