586,070 active members*
3,502 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Spindle motor drive gear source
Results 1 to 6 of 6
    Sep 2006
    296
    Anyone know where i can buy this gear? Part # 20-9125A is what i was told the part # is by Haas.
    I need to get a new drive gear for the spindle motor on an old '98 HS-1 20hp machine. Called Haas and they want me to buy a new transmission with a new motor already in it. I can not spend a ridiculous amount of $$ on a bunch of brand new parts i dont need all because they will not sell me the $300 gear i need. Their service is getting worse every year. This is ridiculous.
    As a last resort i guess i can make a new gear. I do run a machine shop after all. Id just rather spend a little $$ to save some time and headache.
    Dec 2013
    5717
    Re: Spindle motor drive gear source
    Can you match it up with something from Boston Gear?
    Jim Dawson
    Sandy, Oregon, USA
    If you have the specs, we could Hob one for you. Is there enough of the old one to get the data from?
    Sep 2004
    148
    Quote Originally Posted by GITRDUN View Post
    To add insult to injury, I think the HFO has to install the unit, if you install the unit the warranty is void.
    Sep 2006
    296
    I modeled the origional and with a little fancy programming we made one from some 4140 and put it all back together. Got back up and running in short order. Still running fine.
    Dec 2013
    5717
    Good for you :cheers:
    Jim Dawson
    Sandy, Oregon, USA
  1. I.H. Belt drive conversion spindle drive sleeve gear
    By Roadstercycle in forum RF-45 Clone Mill
    Last Post: 04-23-2018, 12:43 AM
  2. Replies: 0
    Last Post: 11-12-2016, 01:46 PM
  3. VF2 Spindle Drive Fault F, Falls out of high gear
    By standfast in forum Haas Mills
    Last Post: 03-31-2015, 03:04 PM
  4. DC Gear motor axis drive?
    By leaveme in forum CNC Machine Related Electronics
    Last Post: 09-21-2010, 03:45 PM
  5. Spindle motor encoder source?
    By Ranchero50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-28-2008, 03:42 PM
