586,072 active members*
4,389 visitors online*
    Nov 2006
    65
    Hotkeys not working
    Hey all, I don’t know if I can quiet explain this, but here goes. My pendant hotkeys for the x,y,and z are not working. The pendant is working properly, and you can program it to the hotkeys screen, with all the inputs working as advertised, but the axis’ will not move unless you use the Mach “tab” pendant. It worked before, and it works on my other machine, just one day stopped. I have looked to see if there is any activate/deactivate hotkeys, but I haven’t found anything. Short of reloading Mach, I have no idea what to do.
    Re: Hotkeys not working
    Check if you are in MPG mode or jog mode.
    Nov 2006
    65
    You know, I checked that, and I didn’t think about it till you said something....it wouldn’t let me select between increment, continuous, and mpg on the jog mode......none were lit up
    Then jogging is turned off.
    Note that jog hotkeys will not work unless there is a jog on/off button on the page of the screen you are on.
    Nov 2006
    65
    I have no idea where that would be
  1. hotkeys
    By radioman in forum Mach Mill
    Last Post: 12-07-2011, 10:42 PM
  2. Zero X & Y and Ref Z Hotkeys
    By Wolfesmetalfab in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-12-2010, 03:21 AM
  3. Rhino hotkeys?
    By mikko321 in forum Rhino 3D
    Last Post: 02-11-2010, 08:55 PM
  4. Feedhold hotkeys not working
    By thedoctor in forum Mach Plasma / Laser
    Last Post: 10-05-2008, 11:15 PM
  5. My rhino hotkeys
    By ohno in forum Rhino 3D
    Last Post: 04-04-2007, 09:26 AM
