586,096 active members*
3,727 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > Just starting to use g68 g69 now need help with WCS x0.y0.
Results 1 to 2 of 2
    Apr 2014
    26
    Hi folks. I have been cutting simple 2d parts for a while now, and am now trying to make it easier to organize parts on a sheet of material. I just discovered g68 and g69 for rotating the code file and that is a huge step in the right direction. Im running in to a problem though. If I have a part, and I rotate it lets say 90 degrees left starting from x0y0 on bottom left, then the start point remains in the same location on the part, but that is now bottom right.
    So, what I want to do is be able to rotate the part program in any direction at any angle but keep my x0y0 in lower left. I generally work left to right bottom to top when using a sheet of material. Is there a code or sequence I can use to move my x0y0 back to lower left when i rotate the part program? Is there a program to just rotate the original and save it as a new program where in I could manually move my x0y0 and add entry and exit paths?
    I just want to rotate around z axis, and keep x0y0 at bottom left. Thanks!
    Attached Thumbnails Attached Thumbnails IMG_20180228_170330.jpg   IMG_20180304_180218.jpg
    Apr 2014
    26
    Re: Just starting to use g68 g69 now need help with WCS x0.y0.
    As in the pictures below,I would like to be able to really make the most of a sheet of carbon fiber. I figure my waste material is about 20-25% right now if Im lucky. Would like to reduce that to about 10% or less.
  1. HF starting or pilot arc starting?
    By unns_boy in forum Hypertherm Plasma
    Last Post: 05-08-2013, 01:33 PM
  2. Starting out...what do I need?
    By MynamesKenny19 in forum Uncategorised MetalWorking Machines
    Last Post: 10-05-2011, 02:41 AM
  3. Replies: 2
    Last Post: 06-30-2008, 09:54 PM
  4. Need help starting
    By agenso585 in forum Diemaking / Diecutting
    Last Post: 02-05-2007, 08:56 PM
  5. Just starting out
    By BawFlinger in forum OneCNC
    Last Post: 10-18-2006, 09:13 AM
