586,645 active members*
2,702 visitors online*
Thread: Dust Boot
Results 1 to 10 of 10
    Jun 2012
    393
    Dust Boot
    Does anyone have plans or pictures of a non moving dust boot.
    I would like to have one that does not go up and down with the
    router.
    I have and older style CRP2448
    Thank You
    Don
    The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
    Apr 2003
    540
    Re: Dust Boot
    You don't see too many that don't attach directly to the spindle or router if that is what you mean. I don't remember the site, but there are a couple of versions that mount to the Z axis base (where it mounts to the gantry) with 2 rods, and you can set the boot height with thump screws. A little searching on the web or you tube should locate them. On those of this design I have seen, the spindle goes up and down within the boot. These designs may work with a very good vacuum system, but the more "gaps" that allow air to flow from other than directly under the spindle the less efficient the vacuum is.
    Apr 2010
    82
    Re: Dust Boot
    I designed one and installed it just before going away for the winter. In a few tests it worked very well, but I have in mind some changes which I will do when I get home in a month or so. When I am happy with it, I'll post the drawings. Mine uses a pair of brackets that mount to the sides of the Z axis plate. I use a large dust collection system and the boot has a short brush on it. My machine is a 24x48 pro but has not been upgraded to the new style risers or linear motion. I don't know if the Z axis is the same as yours.
    Jason Beam uses the type of boot you are looking for - check his Youtube channel.
    Jun 2012
    393
    Re: Dust Boot
    KjK2002 I tried to find a video showing Jason's boot and could not . He has a lot of videos.
    I did not see any one else using a static boot. I know there are people using because I have seen them.
    Don
    Apr 2010
    82
    Jun 2012
    393
    Re: Dust Boot
    Auto parts store have heater duct hose that is not as stiff .
    Is this the type you are making. This look good.I may try this one.
    Don
    Jan 2015
    194
    Re: Dust Boot
    Nice shoe and testing videos. Thanks for sharing,
    Jun 2012
    393
    Re: Dust Boot
    I would like to incorporate this floating shoe design https://youtu.be/T1K1gFbxv2M
    with the Jason Beam design.
    I am going to start working on this. If you design something I will be watching.
    Don
    Mar 2005
    109
    Re: Dust Boot
    How do you hold material down when using a dust shoe like this? Vacuum table?
    Jun 2012
    393
    Re: Dust Boot
    He is using screws. I use screws and double sided tape to hold things.
    Sometimes I use clamps. It depends on what I am doing.
    Don
  1. Making a cnc dust boot / dust skirt
    By craynerd in forum Maintenance DIY Discussion
    Last Post: 03-12-2016, 11:29 PM
  2. Anyone have a dust boot on their tormach 770?
    By Stevos758 in forum Tormach Personal CNC Mill
    Last Post: 09-23-2015, 09:56 PM
  3. New Dust Boot
    By distracted in forum Avid CNC
    Last Post: 06-16-2015, 04:36 PM
  4. New Dust boot
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 07-25-2012, 01:45 PM
