586,068 active members*
3,876 visitors online*
    Nov 2005
    222
    Test travel comes up short
    I'm have trouble getting the Z axis to move the specified distance. When instructed to move 1 inch it moves .77 of an inch. I have tried a bunch of difference setting in PncConf Wizard and just can get it to come out right. I even tried setting it up as if the Z screw was a .2 inch screw rather that the metric 5mm screw that the kit was supposed to come with. I don't think it an issue with losing steps because the measurement is the same moving the Z up or down and it is consistent. I have the head counter weighted.
    I'm converting a Sieg X3 mill using the CNCFusion deluxe kit, Mesa 6i25 + &i76 Plug-N-Go kit with a Gecko 203v driver with 10 micro steps on the Z axis. The ball screw has 5mm pitch. I'm having no problem with the X or Y. They are using KL-5056 drivers set to 8 micro steps.
    John
    Nov 2005
    222
    Re: Test travel comes up short
    Someone on the LinuxCNC form said something that made me remember that there were pulleys on the Z and they weren't 1:1. That motor is under a cover and I was so focused of t he software set I forgot about the pulleys.
    John
    Oct 2017
    Measure how much the block moves for one rotation and enter tpi value in "axis scale calculation" and enter "microstep multiplication factor" too.
    Hope that helps.
    Jun 2013
    1041
    Multiply your steps per inch you currently have set by 1.2987. Then replace it with the new number. Should get you pretty close.
    Ben
    Sent from my HTC6525LVW using Tapatalk
    Nov 2005
    222
    I solved it a while back. I forgot that the Z went through pulleys that were not 1:1 because the Z motor was on the back of the mill under a cover. Out of sight out of mind.
    John
  1. Replies: 18
    Last Post: 09-15-2014, 02:09 PM
  2. 1/32 short in 48" of travel
    By litleboy in forum Commercial CNC Wood Routers
    Last Post: 08-20-2014, 01:26 AM
  3. how short is too short for necks?
    By qotsarock in forum Musical Instrument Design and Construction
    Last Post: 10-26-2010, 04:55 PM
  4. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
